nightcore500
- Apr 1, 2022
Greetings,
I updated my TrueNAS Scale instance from Bluefin to Cobia today. The instance was previously running on version 22.12.0 (Bluefin). I first updated from 22.12.0 to the latest Bluefin version 22.12.4.2. The update went through without any problems. After this update I switched to the latest Cobia Release Train version 23.10.1.3. After the instance booted again I got the following alert:
"Attempt to connect to netlogon share failed with error: [EINVAL] Automatically disabling ActiveDirectory service due to invalid configuration.."
The status of the Active Directory service suddenly changed to "FAULTED".
I then tried a rejoin. This failed with this message:
"No server IP addresses passed DNS validation. This may indicate an improperly configured reverse zone. Review middleware log files for details regarding errors encountered."
The middlewared.log contains the following:
"[2024/02/09 16:04:06] (WARNING) ActiveDirectoryService.ipaddresses_to_register():105 - No nameservers configured to handle reverse pointer for 10.30.2.101. Omitting from list of addresses to use for Active Directory purposes."
After unchecking the Active Directory setting "Allow DNS Updates", the connection to the AD was suddenly possible again and the status was HEALTHY again.
The nameservers are 2 interconnected Windows AD servers which both provide a DNS server. No changes were made to these servers.
I also have a second TrueNAS Scale instance which I only use as a replication server. This is currently still on the old Bluefin version and has no problems with the AD.
Is this a bug in the current Cobia Release Train?
