Activate SED(Opal) encryption before or after creating pool?
orjan-
I'm setting up a samsung 970 evo plus nvme ssd to use SED(Opal) encryption and this drive will be used as a single drive in a data pool.
Should a pool be created before activating SED encryption, or should I first enable SED encryption and then create the pool?
Both ways seems to work if they are done without a reboot in between. However activating SED, reboot, and create pool in that order fails.
Case created:
https://jira.ixsystems.com/browse/NAS-103567
orjan-
Which verson of FreeNAS (as in 11.2-U6?)?
Yes, currently testing on 11.2-U6.
sedutil-cli is not very well documented. I have tried to first create pool and then enable SED, and to enable SED first and then create the pool. In both cases i get a warning at boot that there is a issue with the primary partition table and that it's using the secondary partition table instead. I'm guessing that sedutil-cli creates a shadow partition table as primary partition table. However in the documentation, it only mentions that partition table if the PBA image is loaded, but I dont think thats the case on freenas data pool as it's not a boot drive and PBA is only necessary for unlocking boot drives. I think the MBRDone and MBREnable are only nesscessary if using PBA, but they get enabled by default also when following non-boot drive setup with sedutil-cli and when using sedhelper.
I just want to know if there is a right way or a wrong way. If it messes with alignment or something like that if done in the wrong order.
D
dlavigne
Guest
Please create a report at bugs.ixsystems.com and post the issue number here. We would like to improve the documentation and also want to verify that it is working correctly.
orjan-
Created case and added link in the first post.
