3nm1
 - Jul 11, 2019
Have a bit of an language barrier issue, i followed the documentation for replacing a failed drive in my encrypted pool, after the resilvering the pool status shows as healthy, but I get stuck at this part in the documentation:
Wait until resilvering is complete before restoring the encryption keys to the pool. Restore the encryption keys before the next reboot or access to the pool will be permanently lost.
But since the only options I got are the following:
The pool was created a while ago, and i added a passphrase, and downloaded both the recovery and encryption keys, at that time,
And i downloaded the encrypt key before doing the disk swap.
Is there any way i can verify that everything is in order, before rebooting? It´s not the most valued data, and the server is just for my personal home use, but it will take a while to rip all my blue rays and dvd's again...
- Create passphrase
 - Add recovery key
 - Delete recovery key
 - Encryption Rekey
 - Download Encrypt Key
