I fished setup of my main server yesterday and did a new install of freenas-11.2-U7. This server has two pools:
ssd0:
a single samsung 970 evo plus with SED encryption enabled but auto locking disabled due to a bug in sedhelper not unlocking nvme drives. It has the default "MBRdone=N" and "MBRenabled=Y" set and this seems to block changes to the partitions on the drive.
ashift 13.
volume0
8x wd red 10TB in raidz2 with geli encryption.
Connected to onboard intel C246 sata controller.
Ashift 12.
I installed freenas, created pools on the web-gui and created dataset and ACL on the CLI. I created 4 jails on ssd0 that were running with almost no activity.
18:00 i started a 13TB SMB transfer over 1gbit to volume0.
23:50 i added 2 usb3.0 ntfs disks and started copying the contents on the CLI to volume0.(1TB and 5TB of data)
03:02 i get this email:
Checking status of gmirror(8) devices:
Name Status Components
mirror/swap0 DEGRADED ada7p1 (ACTIVE)
mirror/swap1 COMPLETE ada6p1 (ACTIVE)
ada5p1 (ACTIVE)
mirror/swap2 COMPLETE ada4p1 (ACTIVE)
ada3p1 (ACTIVE)
mirror/swap3 COMPLETE ada2p1 (ACTIVE)
ada1p1 (ACTIVE)
-- End of daily output --
When i logged into the web-gui to see what was going on, there was no error on the bell icon. However there was this error in console from 01:45 saying that the swap on the nvme ssd had problems and not ada7(sata wd red hdd) as stated in the system warning email.
This is all the info from console:
Nov 21 00:00:00 freenas syslog-ng[2944]: Configuration reload finished;
Nov 21 01:45:21 freenas nvme0: WRITE sqid:11 cid:89 nsid:1 lba:144 len:16
Nov 21 01:45:21 freenas nvme0: ACCESS DENIED (02/86) sqid:11 cid:89 cdw0:0
Nov 21 01:45:21 freenas GEOM_MIRROR: Request failed (error=5). nvd0p1[WRITE(offset=8192, length=8192)]
Nov 21 01:45:21 freenas GEOM_MIRROR: Device swap0: provider nvd0p1 disconnected.
So my questions are:
Do I have a problem with swap on ada7 or is freenas mail notification reporting nvme0 as ada7 due to a bug causing "if unknown, report highest adaX as problem source"
I'm new to freenas, freebsd and ZFS, but I have some general experience with linux and CLI. Is there anything I can check so see if there ever was a problem with ada7 or any of the drives in volume0(ada0-ada7)?
The MBRdone and MBRenabled variables(sedutil-cli) on SED drives are not very well documented in sedutil-cli documentation or freenas. They seem to block changes to a drive so that it can not be repartitioned or get a secure erased once changed to their normal values "MBRdone=N" and "MBRenabled=Y". They change to these values after the first power cycle after enabling SED. If freenas tried to do something partition related at 01:45, then that could be the answer for the error 01:45 as the "MBRdone=N" and "MBRenabled=Y" might have blocked a partition change from happening.
Any suggestions?
I have not rebooted or done anything else then logging into the web-gui after it happend. The 13TB SMB transfer still has 24 hours left, so I was hoping to avoid a reboot until it finishes.
			ssd0:
ashift 13.
volume0
Ashift 12.
ada5p1 (ACTIVE)
ada3p1 (ACTIVE)
ada1p1 (ACTIVE)
Any suggestions?
