Accidentally installed apache24 in freenas console
twsps
Hi everyone,
While I was installing nextcloud on freenas, I accidentally installed apache24 in freenas console instead of jail console. Now my freenas.local turns to It works! instead of my web gui.
However, using freenas.local/ui is able to access new web gui and freenasip is able to access old gui.
How am I able to remove apache24 installation on my freenas?
Thanks.
It may be as simple as reboot. (unless you did mount -uw / first, the changes you made to the host would not be permanent)
It should not have been possible to make that error as pkg is not configured on the host, only in jails.
twsps
It seems like freenas.local is linked to my jail's ip, so it's showing it works and nextcloud web interface when using freenas.local/nextcloud
How should I fix this?
It seems like freenas.local is linked to my jail's IP
So if you use the IP of your host to connect to the GUI?
If that works, it seems it would just be a case of having your jail not register the same dns name as the host.
twsps
Yes, using FreeNAS' IP address (192.168.0.134) will get into old web GUI.
So if it's like this, how can I solve this?
Sent from my Mate 9 using Tapatalk
Jailer
Not strong, but bad
Jailer
Not strong, but bad
Then you didn't install it on the base system. That means you have a jail configuration issue to work out.
twsps
My nextcloud iocage doesn't use vnet, when I enable vnet on nextcloud13, I'm not able to open nextcloud web gui after freenas restart. So how would I solve this?
Assuming that the problem is that the bridge for the vnet is not containing your NIC, you could create a tunable to add it.
Test first with ifconfig bridge0 addm igb0 up
I assume your NIC is igb0 in that example.
twsps
When I stop my Nextcloud iocage, then freenas.local will work fine and direct me to freenas web gui. So your estimation might be true.
This is what I found in Nextcloud iocage jail:
root@nextcloud:/ # ifconfig
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
	ether xx:xx:xx:xx:xx:xx
	hwaddr xx:xx:xx:xx:xx:xx
	inet 192.168.2.76 netmask 0xffffff00 broadcast 192.168.2.255
	media: Ethernet autoselect (1000baseT <full-duplex>)
	status: active
	options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
	groups: lo
	groups: bridge
	member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 5 priority 128 path cost 2000
	member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 4 priority 128 path cost 2000
	member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
			ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	status: active
	groups: epair
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
	options=8<VLAN_MTU>
	status: active
	groups: epair
How can I fix?
If you run sysrc -a in the jail, do you see a host name defined?
twsps
root@nextcloud:/ # sysrc -a
apache24_enable: yes
cron_flags:  -J 15
host_hostname: nextcloud
ipv6_activate_all_interfaces: YES
mysql_enable: YES
redis_enable: yes
sendmail_enable: NONE
sendmail_msp_queue_enable: NO
sendmail_outbound_enable: NO
sendmail_submit_enable: NO
syslogd_flags: -c -ss
twsps
root@freenas:~ # ifconfig
	inet 192.168.2.134 netmask 0xffffff00 broadcast 192.168.2.255
	status: active
I believe the underlined part is the issue. It directs me to the jail's ip
So I think what you're saying is that you have a second IP address defined on re0 on your FreeNAS host which is the same as your jail IP?
Under Network Interfaces in the GUI, what do you see? Have you added aliases to your main interface?
Also, do you have allow_raw_sockets in your jail (are we iocage here?... maybe try iocage get -a nextcloud)?
twsps
Yes, image attached to what you're referring
twsps
Yes, allow_raw_sockets=1 when setting iocage
allow_raw_sockets:1
ip4_addr:mynetworkinterface|jailip/24
vnet:off
vnet0_mac:xxxxxx,xxxxxxx
