Access FreeNAS via explorer
ottoangel
Is it possible to access FreeNAS directly? I had an old FreeNAS installation and on that one I could do it but with this new one (11.1) I can't get it to work. I made a dataset called 'Backup FreeNAS' and that works but it is not so convenient because you have to add it.
garm
Vad är det du vill åstadkomma?
What do you want to achieve?
ottoangel
I just want to doubleclick on 'FreeNAS' and then I want all my folders and files to be visible.
