9.3 Upgrade Data Folder Hierarchy
mskenderian
so i just upgrade to 9.3
My pools name was Data... still is...
now when i browse the folders i see /mnt/Data/ my normal stuff
and i see /mnt/mnt/Data/jail/
in the that folder there is all the .warden templates. it was not there before i upgraded, and now its there.
Is it safe to delete???
Also in the GUI, under Storage->Volumes
I now see Data/Data/then my normal stuff.
Is this normal? Why is there two Data "Folders"
D
dlavigne
Guest
Can I delete /mnt/mnt/Data/jail/ then the .warden templates ?
I wouldn't. They take up very little space and are needed if you ever want to use plugins/jails.
diedrichg
the templates get re-downloaded once you create another jail/plugin.
D
dlavigne
Guest
They're supposed to. However there's dozens of forum threads from unhappy users who nuked these datasets and then had probs afterwards.
mskenderian
it used to be in /mnt/Data/jail
but it moved, i dont mind having it in mnt/Data/jail, i just dont want it in /mnt/mnt/Data/jail
D
dlavigne
Guest
Can you post a screenshot? I think it is because you have a pool/dataset named data and a FreeNAS upgrade saves a copy of the old system dataset on its own data dataset.
mskenderian
here u go...
