SOLVED 9.10 boot volume 88% used
VictorR
FreeNAS-9.10-STABLE-201606072003 (696eba7)
I just noticed this recently - 6.4GB of 7.2GB used
Is this an issue? Will it be one soon?
Can I, or should I, delete some of those older snapshots?
nojohnny101
Yea it will become a problem.
Seems like you have installs dating back to January. Any reason you are keeping them around? I usually only keep 2 versions back.
VictorR
No reason, I hadn't been paying until to the boot volume.
Thanks for the advice, I'll delete everything before the last two versions
Jailer
Not strong, but bad
If your current boot environment is good and stable get rid of some of those old boot environments. I keep the original, 1 previous and the current on my boot device as long as everything is running smoothly.
VictorR
Freed up 4.1GB, down to 31% used
