I did the GUI upgrade, which seems to have gone fine. I upgraded form 8.3.1 and zpool version 28. After I upgraded the system, I did the zpool upgrade, but no version shows now when I type: zpool get version MAIN. Is this normal?
I set one of my datasets to LZ4 compression, but it doesn't appear to be working and the compression ratio is x 1.0. I'm not sure how to change the ratio or if that's possible? I looked around for a few hours yesterday but couldn't find the answer. I'm trying to compress a volume that holds MKV files.
Update: Compression does work, but not on mkv files.
