8.0.1 Beta2 Box locking up when Physical Memory is Low
H
HwyXingFrog
Guest
I took a look around and couldn't see anyone else having this issue.
Originally when I started using my FreeNAS box I was storing VirtualBox images on the NAS and mounting them remotely, this would use up my 2GB (I know it's low, I'm building a new box with 8GB, I may try to put in 4GB in the meantime).
The FreeNAS box would completely quit responding over the network. The only thing I could do is do the Reboot option (option 10 on the box itself). Even if I try to access the Shell (option 9) it would completely stop responding and have to do a hard power cycle.
I don't have any data since I had to do a hard power cycle, even my WebGui Reporting Stats are lost due to the hard power cycle I had to do last time because I tried to access the Shell.
Is this issue anyone is aware of or seeing?
Thanks.
H
HwyXingFrog
Guest
It just happened again, only took 6 hours this time (had over 2 days of uptime last time before this happened). It seems to be when all the plots on the Physical Memory Utilization converge around 512MB (total memory is 2GB).
I just upgraded the ram from 2GB to 4GB when I did the reboot this time.
Until I figure out what's going on, I'm going to have to keep an eye on it, and reboot the server if it is getting close to 512MB
H
HwyXingFrog
Guest
I have upgraded to 4GB of ram almost a week ago, and had this happen once after 3 days of uptime. I'm almost at 3 days of uptime again and it looks like it could stop responding soon since it is hovering around the 1GB mark (where it stopped responding 3 days ago).
I would like to upgrade to BETA4, but I don't know if it will help.
Thanks.
Tekkie
It looks like I am in the same place as you and unfortunately even limiting the amount of memory available to the kernel and ZFS cache the system will still lock itself up, and I am on BETA 4.
