5 discs not getting smart tested
ethereal
i had all 12 discs setup with long tests and short tests
now i noticed that freenas only has 7 discs out of 12 selected for both my tests - i definitely didn't change anything in freenas so obviously annoyed the tests are not being done as i set them up.
i have had something similar happen before in freenas so i was using a script to check that the tests were being done and they were all okay
just letting people know that freenas has let me down twice so you need to keep on top of the smart tests
D
dlavigne
Guest
What is the difference between the disks that are tested and those that aren't? eg manufacturer, cabling, etc.
ethereal
my 10 hdds are all western digital - my 2 ssds are intel
12 devices in total - 8 hdds on my hba (5 of these have the tests disabled - da0, da1, da2, da3, da4)
2 hdds and 2 ssds on the m/b all okay
D
dlavigne
Guest
Please create a report at bugs.ixsystems.com and post the issue number here.
ethereal
i'm still having problems. all the short tests are running daily as scheduled but there are still 5 discs not getting long tests.
i have all 12 discs selected for the long test but it is only running on 7.
when i have time i will create a bug report
ethereal
after i recently changed the schedule all the tests ran as expected.
still don't know why the 5 discs became deselected originally
