Hi All,
I wanted to run my backup idea through you guys who have been doing this for a while. I have a 3 disk single zfs pool with all 3 disks in mirror configuration. The disks will be using zfs native dataset encryption.
I would like to take 1 of the disks “offline” (using the offline command) and store it offsite for a few months to provide redundancy against physical damage to the server. The offsite disk will be reintroduced to the pool months later and “onlined” into the pool. The disk should resilver when I do this. I would then take one of the two drives which have been running on the server offline and offsite and repeat this process to maintain offsite redundancy.
What are your thoughts on using this method? I understand I can take a snapshot and send it to a drive outside the pool but I would like to rotate through all 3 drives not just keep backups on one drive solely. ZFS sending to an external server is not an option. I also understand connector wear (from swapping drives) is a factor I will have to take into account with this method.
Say if the server burns down, will the offsite disk that is encrypted and belongs to the pool be able to be brought online on a new computer and data accessed?
Will ZFS complain about the offline drive? I would like to monitor the health of the remaining 2 disks in case one of them fails. I supposed I could ignore the offline drive and just check ZFS status of the remaining two.
Thanks for your feedback.
