Hey, I'm looking to do a FreeNAS build for
Do you guys think heat will be an issue?
Is there anything wrong with this boot setup?
Is there any reason I should switch to the Avoton 2750? I've seen some benchmarks that show the 2750's turbo boost is significant- I just don't know if it is worth it in a real world application
I'm probably going to hold-off and wait for FreeNAS 10... I have only skimmed the 10 material - any reason this is a bad idea?
Thanks
- Transmission
- Crashplan/Rsynch (or some other way of locally backing up my devices and then to the cloud)
- Emby (occassionally transcoding HD content, 1 maybe 2 streams)
- OwnCloud (less than 500mb back and forth/month)
- Couchpotato
- Back up Media
- Mirrored Bootdisk: 2x SanDisk Ultra Fit CZ43 16GB
- Fractal Node 304 White
- SeaSonic SS-400FL2 Active PFC F3 400W 80 PLUS Platinum Fanless
- Supermicro A1SRI-2758F-O
- 4x KVR16LSE11/8 (32GB of Kingston 1600 RAM)
- 6x WD Red 6TB (run in Raid-Z2)
- 1 TB WD Portable to run Transmission off of...
Thanks
