Hi everyone,
I've decided to give SCALE a go and I'm trying to upgrade to 21.06 from CORE 12. Following the steps in the getting started guide when I proceed with the upgrade, it always terminates with the following error:
Can anyone tell me what's happening? I can't seem to find this issue reported anywhere else.
cannot create 'boot-pool/grub': dataset already exists [0%] Creating dataset [0%] Extracting [90%] Extracting [90%] Performing post-install tasks Error: Command ['chroot', '/tmp/tmpvm64487u', 'update-grub'] failed with exit code 1: /usr/sbin/grub-probe: error: failed to get canonical path of /dev/sdh2'. Traceback (most recent call last): File "/usr/lib/python3.9/runpy.py", line 197, in _run_module_as_main return_run_code (code, main_globals, None, File "/usr/lib/python3.9/runpy.py", line 87, in _run_code exec(code, run_globals) File "/mnt/truenas_install/_main__.py", line 414, in <nodule> main() File "/mnt/truenas_install/__main__.py", line 341, in main ["chroot", root, "update-grub"]) File "/mnt/truenas_install/_main__.py", line 53, in run_connand File return subprocess.run(cmd, **dict(run_kw, **kwargs)) File "/usr/lib/python3.9/subprocess.py", line 528, in run raise CalledProcessError (retcode, process.args, subprocess.CalledProcessError: Command '['chroot', '/tmp/tmpvm64487u', 'update-grub'] ' returned non-zero exit status 1. The TrueNAS upgrade on sdc has failed. Press enter to continue...
