malventano
- Apr 13, 2020
I was testing Shadow Copy via SMB on 11.2, and figured I would wrap up with an upgrade to 12 to see what broke. The update to 202004100424 was seamless, as was upgrading the existing test pool, but I noted that while snapshots were still properly appearing in the 'Previous Versions' tabs under Windows, opening either a folder or a previous version of a file always accesses the contents of the current (not previous) folders/files. Rollback of snapshots via TrueNAS functioned as expected, but snapshot mapping via SMB appears to be broken currently.
To poke the issue further, I went as far as deleting all snapshots/shares and creating a new share, adding files, making a new snapshot, changing file contents, and re-confirming that the current (wrong) version presents when opening Previous Versions via SMB.
Separately, I noted that the default page presented for adding a Samba share (share/SMB/add) does not honor the current 'Show Advanced Fields by Default' setting and always displays the basic page, requiring the user to toggle the basic/advanced button twice to get advanced options to appear. I spot-checked a few other pages and those worked correctly, so this appears limited to the just the SMB/add page.
