2 drives failed and both have been replaced, but I can't seem to figure out how to rebuild my ZFS RAIDZ2 (RAID6) array, I found some tutorials but they were outdated, help is appreciated!
I don't have any disks showing offline, I didn't know I had to manually put the disks to offline status first, so do I have to re-install the failed disks again, tell the system they're offline then replace or what?
I think I got it, it's Resilvering now, I told it to replace the disks for the unavailable drives (there was no option to toggle them offline) and I told it to replace one each with the new drives I had installed. It gave me some message about a partition or something, and I checked the box to force it. This is probably going to take awhile!
Thanks for the help @gpsguy, your tip with the zpool status was really helpful!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
