12-Release; Reports broken, possible work-around
jenksdrummer
Changed theme from iX Dark to iX Blue; reports now work; seems to also work under Midnight theme. Change it back to iX Dark, and gone.
kspare
This worked for me as well...I had to change it a few times to get it working....
hescominsoon
i can confirm this behavior as well..ixdark reports are blank.
mccann73
Confirmed here as well, iX Blue fixes reporting.
helios_x
An extra full reboot did the trick for me!
Pitfrr
For me it didn't work... Extra reboot didn't change anything. ;-(
In ix.dark theme I can't get the reports to show. Working with all the other themes though.
Tried with two different browsers: Firefox and Chrome.
Also noticed that once you're in the report page (with the reports not showing), you need two clicks to get something back from the UI.
For example, when in reports:
If I click on Dashboard, I get an empty screen but still showing Reporting/CPU:
I can click as many times I want on "Dashboard", same page.
I have to click on an other section (for example "Services") to get the desired menu.
Dohmar
Yeah, reboot didn't change anything for me, and I notice the same UI glitches. Im sure the team will have a fix soon.
Pitfrr
Yep, it's a minor and cosmetic issue so not very urgent I'd say.
And apparently the workaround (using a different theme) seems to be working well so definitely not a big deal.
I'm very happy with the release itself! Thanks to all the team!
Kris Moore
SVP of Engineering
Administrator
Thanks for digging into this folks! We're looking at fixing up the bugs in the themes, but glad we have a work-around in the meantime :)
kspare
is anyone else having an issue with firefox and scroll bars disappearing until you refresh?
sophware
sophware
Thank you!
In my case: Changed to Midnight w/ no improvement. Changed to IX Blue, fixed. Changed back to IX Dark, broken again. Changed to IX Blue again and left it fixed.
jenksdrummer
Worth noting, seems this breaks even after changing it seems to fix it...if on a different computer/browser. I just change it between whatever it was to something else and the reports appear.
