12 bay hot swap case. Unknown chinese brand. Anyone tried it?
ShimadaRiku
Stumbled on this case
Not exactly sure who makes them, but kinda want it. Unsure of how to order them or if the backplane is good.
Has 12x hot swap bays & compact in size. Other small case such as ds380, ITX-S8 or NSC-800 only have 8 bays.
Has anyone tried this case or seen it reviewed somewhere?
listhor
It's been some time since you asked... Did you finally purchase that case? If so, what's your impression?
Lord Baldrick
How did it turn out?
listhor
Ultimately I purchased this: https://www.alibaba.com/product-detail/4U-rack-mount-server-case-with_60684153029.html
Pros:
  • Size I want :smile:
  • Price
  • Overall quality isn't bad
Cons:
  • HDD bays aren't perfectly aligned. I mean when inserting bay into chassis you must "play" a bit while doing so
  • built in fan controller isn't for PWM fans
  • as a result included fans are non PWM fans. I ended up buying those gray, 80mm Noctua fans and I connected them directly to mobo.
Lord Baldrick
Pros:
  • Price
Cons:
Thanks … unfortunately that Alibaba link doesn’t work for me.
listhor
Wholesale 4U rack mount server case with HDD tray industry rackmount chassis From m.alibaba.com.png
It does work…
