Reboot, select your old version in the grub boot menu. Remove the 11.2 version (go to system->boot in the GUI).
Use the upgrade path 9.10->11.1->11.2 ->11.3
If you have jails in 9.10 you'll need to convert them from warden to iocage before moving from 11.2 to 11.3. Search here for information - this resource https://www.ixsystems.com/community...darr-lidarr-jackett-transmission-organizr.58/ covers many of the most commonly used jail applications.
Thanks! Now I have solved the issue. I'm happy I had saved a settings config file that I could load.
At the same time I had problem with a static ip config on my router I solved.
I'm now at version 11.2 and went first to 11.1. Thx again!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
