Reboot, select your old version in the grub boot menu. Remove the 11.2 version (go to system->boot in the GUI).
Use the upgrade path 9.10->11.1->11.2 ->11.3
If you have jails in 9.10 you'll need to convert them from warden to iocage before moving from 11.2 to 11.3. Search here for information - this resource https://www.ixsystems.com/community...darr-lidarr-jackett-transmission-organizr.58/ covers many of the most commonly used jail applications.
Thanks! Now I have solved the issue. I'm happy I had saved a settings config file that I could load.
At the same time I had problem with a static ip config on my router I solved.
I'm now at version 11.2 and went first to 11.1. Thx again!
