11.3 Vmware-Snapshots not showing all datastores
websmith
I very recently upgraded from version 11.1 to 11.3 because I heard that NFS 4.1 was finally working properly with vSphere.
I have been relying on the Vmware-snapshot feature so my zfs snapshots are consistent.
But it seems like something in the change from 11.1 to 11.3 broke the integration somehow.
This list only shows two datastores, even though the server in question have two NFS4.1 datastores located on two different FreeNAS servers.
the "slow" datastore is a NFS3 datastore and the vms2_nvme2 is a locally attached u.2 drive - but none of my nfs4.1 datastores are shown.
Has anyone else experienced this - and is there somewhere I can look to see why there are two datastores missin in the list?
If I had to guess it could be that a statement somwhere does not handle nfs4.1.
This is my list of datastores as seen from vSphere:
I'm running vSphere 6.7.
Thanks
Rand
Hey,
have you ever been able to fix this?
I'm having the same issue on 12U1 ...
Thanks
websmith
No,
Since I got no response here I just reverted to NFS 3 which just "works".
Regards
websmith
Just added a comment on the jira ticket - to make it precise that it only happens with nfs4.1
JoeAtWork
Still broken on TrueNAS-SCALE-22.12.1 as well, NFSv3 does work. it should be easier when using NFSv41. I am using SYS for security....
