Hi.
After upgrading to the beta I seem to have sqlite issues, previous threads suggests this is related to failing storage, however I run the OS on a pair of SAS drives mirrored, doesn't seem to be the issue.
Opening the sqlite the file appears fine
but whenever I try to do changes to config, like tunables or acl settings of a smb share I get the following
I have logged a jira, but didn't get picked up by anyone yet
mirai% sqlite3 freenas-v1.db
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/datastore/connection.py", line 62, in execute_write return await self.middleware.run_in_executor(self.thread_pool, self._execute_write, sql, binds) File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1102, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/datastore/connection.py", line 65, in _execute_write result = self.connection.execute(sql, binds) File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 976, in execute return self._execute_text(object_, multiparams, params) File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1145, in _execute_text ret = self._execute_context( File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1287, in _execute_context self._handle_dbapi_exception( File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1481, in _handle_dbapi_exception util.raise_( File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py", line 178, in raise_ raise exception File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1247, in _execute_context self.dialect.do_execute( File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py", line 590, in do_execute cursor.execute(statement, parameters) sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) unable to open database file [SQL: INSERT INTO system_tunable (tun_value, tun_type, tun_comment, tun_enabled, tun_var) VALUES (?, ?, ?, ?, ?)] [parameters: ('YES', 'loader', '', 1, 'fuse_load')] (Background on this error at: http://sqlalche.me/e/e3q8)
