integrity error when setting up iSCI for ZVol
Phalanxguard
Hi, has anyone encountered the following error when setting a ZVol ISCI through the latest stable TrueNAS? Any solutions? The configured pass for it is 12 alphanumeric characters. Works fine when CHAPS is not enabled.
integrityError (sqlite3.IntegrityError) NOT NULL constraint failed: services_iscsitargetauthcredential.iscsi_target_auth_peersecret [SQL: INSERT INTO services_iscsitargetauthcredential (iscsi_target_auth_tag, iscsi_target_auth_user, iscsi_target_auth_secret, iscsi_target_auth_peeruser) VALUES (?, ?, ?, ?)] [parameters: (2, 'Druv', '3aMu6YvBB1Nvh4CgWxFtHP7bcEt4mTp2S/1g27z7YG9wt8AaCyKuEx==', '')] (Background on this error at: http://sqlalche.me/e/gkpj)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1247, in _execute_context
    self.dialect.do_execute(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py", line 590, in do_execute
    cursor.execute(statement, parameters)
sqlite3.IntegrityError: NOT NULL constraint failed: services_iscsitargetauthcredential.iscsi_target_auth_peersecret
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1195, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/service.py", line 455, in create
    rv = await self.middleware._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/iscsi.py", line 333, in do_create
    data['id'] = await self.middleware.call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/datastore/write.py", line 31, in insert
    await self.middleware.call('datastore.execute_write', table.insert().values(**insert))
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/datastore/connection.py", line 65, in execute_write
    return await self.middleware.run_in_executor(self.thread_pool, self._execute_write, sql, binds)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/datastore/connection.py", line 68, in _execute_write
    result = self.connection.execute(sql, binds)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 976, in execute
    return self._execute_text(object_, multiparams, params)
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1145, in _execute_text
    ret = self._execute_context(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1287, in _execute_context
    self._handle_dbapi_exception(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py", line 1481, in _handle_dbapi_exception
    util.raise_(
  File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py", line 178, in raise_
    raise exception
sqlalchemy.exc.IntegrityError: (sqlite3.IntegrityError) NOT NULL constraint failed: services_iscsitargetauthcredential.iscsi_target_auth_peersecret
[parameters: (2, 'Stephen', '3aMut1RcB1Nvh4CgWjLLqP7bcEt4mTp2S/1g27z7YG9wt8AaCyQkXg==', '')]
MDPD
Yes, the same problem, SCALE-20.12-ALPHA
(sqlite3.IntegrityError) NOT NULL constraint failed: services_iscsitargetauthcredential.iscsi_target_auth_peersecret [SQL: INSERT INTO services_iscsitargetauthcredential (iscsi_target_auth_tag, iscsi_target_auth_user, iscsi_target_auth_secret, iscsi_target_auth_peeruser) VALUES (?, ?, ?, ?)] [parameters: (1, 'mdpd', 'tAO+ckO24UKYnAZiwwT0GwxGFIluRSI4g1RlhcKwwTkmnNrWbskdEg==', '')] (Background on this error at: http://sqlalche.me/e/13/gkpj)
habouji
Same here with TrueNAS-12.0-U1.
    util.raise_(
    raise exception
[parameters: (1, 'testuser', 'gT9mjhKc/1ObfZMC7l5aydcnCbechhPkotqF1JNPDyXELVzkjpir1Q==', '')]
smcclos
I too am seeing this with TrueNAS-12.0-U1, using no CHAP at this time as a workaround.
gheppy
The workaround that I found is to create a user with Peer User to, after which you re-edit it and delete the Peer User part if you do not use it.
The script checks also the Peer User field and it cannot be null. This is the bug.
