mohican
- Jun 8, 2019
I am not a nix user. I am aware that my lack of knowledge is the culprit. I installed FreeNas 11.2 u4.1 with intentions of it being a home server. I configured a storage location (smb) that houses my movie and audio files that are used with plex. It was accessible for read and write access via my windows pcs. After many unsuccessful attempts to upgrade the plex plugin via information from numerous threads, I attempted copy and paste some iocage scripts. I did this for NZBget as well. All of them failed at some point. I started reading the messages and looking at the scripts to figure out the issue. Unfortunately, I made the same incorrect modifications to the last two scripts that I tried. I modified the mnt paths in the fstab lines. This seemed to make sense and removed the final errors. Now, I am unable to get past a permissions issue on two of the folder paths that I added the iocage scripts.
You require permission from Unix User\972 to make changes to this folder
(I do not see this UID in the user's group)
The jails did not work. In an attempt to remove these permissions on my folders I deleted that NZBget and Plex jails restarted FreeNas. The permissions issues still remain. I am about 18 hours into trying to resolve this issue. I can only read files. I cannot add or delete from the folders. Will reverting to a previous configuration file remove the newly added permissions to the folders? I am starting to read about chmod and chown. Can either resolve the issue? My google searches have returned many results but all seemed a little different. I would do a fresh install and start over but that would destroy the folders. I could be completely wrong about the issue. Any assistance will be appreciated. Thank you.
mohican
Examples: iocage fstab -a nzbget /mnt/NAS/Storage/Downloads /config nullfs rw 0 0 iocage fstab -a plex //mnt/NAS/Storage/Downloads /Media nullfs rw 0 0 iocage exec plex chown -R plex:plex /config
mohican
