11.2 RC-1 hangs at "Trying to mount root"
drinking12many
Just upgraded to RC1 and it hangs at the point "Trying to mount root" during boot no error etc. I remember with Beta 3 there was a note that mirrored boot drives had an issue, I saw a note somewhere that this was supposed to be fixed in RC1 so I dont know if the fact mine are mirrored USB drives is causing the problem cause I didn't see anything in the release notes saying it was fixed unless I missed it. Does anyone know or can point out in the notes if mirrored boot drives are still an issue or if it was fixed?
Thanks
UPDATE: I turned on verbose logging on boot and then I get "Error updating a read-only database" or something to that effect.
Chris Moore
Just upgraded to RC1 and it hangs at the point "Trying to mount root" during boot no error etc. I remember with Beta 3 there was a note that mirrored boot drives had an issue, I saw a note somewhere that this was supposed to be fixed in RC1 so I don't know if the fact mine are mirrored USB drives is causing the problem cause I didn't see anything in the release notes saying it was fixed unless I missed it. Does anyone know or can point out in the notes if mirrored boot drives are still an issue or if it was fixed?
Thanks
Create a support ticket so the developers can look into it. It is a RC "Release Candidate" which means it still has bugs and they need to know so they can fix it.
drinking12many
