11.1-U2 error
Tim1962
Just downloaded 11.1-U2 and booted initially into the new GUI
Main page and also on system/boot page. Legacy (my current!) gui seems unaffected. DO you need anything else?
Got
Error 201:[ENOMETHOD] Method "summary" not found in "network.general"
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 893, in _method_lookup
	serviceobj = self.get_service(service)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 822, in get_service
	return self.__services[name]
KeyError: 'network.general'
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 150, in call_method
	result = await self.middleware.call_method(self, message)
  File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 109, in __next__
	return self.gen.send(None)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 902, in call_method
	serviceobj, methodobj = self._method_lookup(message['method'])
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 896, in _method_lookup
	raise CallError(f'Method "{method_name}" not found in "{service}"', CallError.ENOMETHOD)
middlewared.service_exception.CallError: [ENOMETHOD] Method "summary" not found in "network.general"
Alecmascot
Me too....it's broke.
Tim1962
In case someone asks, tried downgrade, delete, reinstall/update and still the same. All updates done via the update button from 11.1-u1
Alecmascot
I suggest you open a bug report.
Tim1962
Bug #28622
Gizmo_oO
Just for my info, I am on U1 now. If I get an error, what can I do to move back? Is there a option in the Boot Menu to go back or what do I have to do? Just in case I get the error.
Redcoat
Open the Boot Menu, click on the version you would like to use (presumably the most recent one before the update) and select the Activate button - the message "On Reboot" will appear by your selection. Then reboot to go back to that version.
Meserias
Just updated and I got these errors ....please provide patch or update.
In attached screen captures you can see where I click and what I get.
Error 201: [ENOMETHOD] Method "summary" not found in "network.general"
Error 201: [ENOMETHOD] Method "get_state" not found in "boot"
Error 22:'IOCAGE_SKIP'
Error 201:[ENOMETHOD] Method "set_attribute" not found in "user"
TwistedNL
Use the old GUI. There's been a bugreport already
https://redmine.ixsystems.com/issues/28623
Chris Moore
I am just finding out that there is an update and have not done any testing with the new version.
Are the errors only applicable to the new GUI? / Is it working properly under the old GUI?
ginogino
I saw that bug # 28622 and # 28623, have been closed, but the bug fix will be included in the next release or a fix will be released.
Just tried to log into the new GUI so I could screen capture how awful it is compared to the classic interface. Can't even get into the new interface...
Sheesh. Version: FreeNAS-11.1-U2
Cheers,
Matt
sintax
Hope so, I cant even use the new GUI to manage jails due to the IOcage error mentioned above
northernsky
Is there a way to fix this? I just re-installed after issues trying to move from nightlies to stable.
edit: This error does not seem to appear in the old gui just the new freenas 11 gui. :)
Error:
