after upgrading to 11.2-U2, I get an error in the plex plugin when I try to delete a media file, and the file isn't deleted.
I figured I'd delete and readd the mount point configuration for the jail. However, when I try to add one, I get a traceback:
Anyone know how I can fix this so plex can delete files again?
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 684, in fstab
dump, _pass, index=index
File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1037, in fstab
index=index
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_fstab.py", line 67, in __init__
self.dests = self.__validate_fstab__(self.fstab, 'all')
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_fstab.py", line 194, in __validate_fstab__
exception=iocage_lib.ioc_exceptions.ValidationFailed
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 90, in logit
_callback(content, exception)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_common.py", line 64, in callback
raise callback_exception(message)
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_exceptions.py", line 32, in __init__
collections.Iterable
NameError: name 'collections' is not defined
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1141, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1078, in _call
return await self._call_worker(serviceobj, name, *args)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1105, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1036, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1021, in run_in_executor
