SOLVED 11.0-RC3 - VM - Every Reboot - manually select EFI/ubuntu/grubx64.efi
louissimon
I'm on FreeNAS 11.0-RC3, I've installed Ubuntu 16.04 (UEFI) on the WebGUI everything is good but, every reboot, the OS doesn't come back automatically. I get stuck in the "UEFI Interactive Shell v2.1" - I then need to connect via vnc and go to Boot Maintenance Manager-> Boot From File -> No volume label, pciroot... ->EFI -> Ubuntu -> grubx64.efi
I thought it was a problem with grub, so i've boot in recovery and run a grub update for the bootloader, but still the same issue once i reboot.
Also, when I do a sudo iohyve list, I don't see my VM (but can see it on the WebGui)
Any idea where I should look?
Thanks,
Louis
louissimon
Hi LotLits!
Thanks for the help, everything is working fine now :)
**I've attached a screenshot of the commands - it might help someone
duk242
Louissimon, you're a legend.
Here's the commands to make it work (from the above screenshot)
mkdir /boot/efi/EFI/BOOT
cp /boot/efi/EFI/ubuntu/grubx64.efi /boot/efi/EFI/BOOT/bootx64.efi
