drgregharris
- Aug 31, 2017
Just added a X520-DA2 card to my pre-existing TrueNAS machine which was previously connected by the motherboard gigabit adapter. The X520 is recognized as an interface and is connected at 10gb to a Ubiquiti 48 port switch in one of the SFP+ ports via a SFP+ DAC cable. The x520 obtains an IP address and I can connect to TrueNAS though that IP address, but if I disconnect the network cable from the 1GB port on the motherboard, I lose the ability to log into the machine even with the 10G IP address. If I connect the 1G connection back in, I regain access. I would like to totally disable the onboard NIC and only connect through the 10G connection.
Thanks in advance
Greg
Thanks in advance
Greg
