the intel x520-sr2 is currently installed.
[root@freenas] ~# cat /var/run/dmesg.boot
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE-p10 #0 r262572+4fb5adc: Wed Aug  6 17:07:16 PDT 2014
    root@build3.ixsystems.com:/fusion/jkh/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (3708.04-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x206d7  Family = 0x6  Model = 0x2d  Stepping = 7
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x1fbee3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,DCA,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x1<LAHF>
  TSC: P-state invariant, performance statistics
real memory  = 60129542144 (57344 MB)
avail memory = 58068054016 (55378 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID:  0
cpu1 (AP): APIC ID:  1
cpu2 (AP): APIC ID:  2
cpu3 (AP): APIC ID:  3
cpu4 (AP): APIC ID:  4
cpu5 (AP): APIC ID:  5
cpu6 (AP): APIC ID:  6
cpu7 (AP): APIC ID:  7
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
ioapic1 <Version 2.0> irqs 24-47 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <ALASKA A M I> on motherboard
ACPI Error: [RAMB] Namespace lookup failure, AE_NOT_FOUND (20110527/psargs-392)
ACPI Exception: AE_NOT_FOUND, Could not execute arguments for [RAMW] (Region) (20110527/nsinit-380)
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
acpi_ec0: <Embedded Controller: GPE 0x1e> port 0x62,0x66 on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 27 at device 1.0 on pci0
pci3: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 33 at device 2.0 on pci0
pci1: <ACPI PCI bus> on pcib2
vgapci0: <VGA-compatible display> port 0xe000-0xe07f mem 0xfa000000-0xfaffffff,0xc0000000-0xcfffffff,0xd0000000-0xd1ffffff irq 32 at device 0.0 on pci1
pci1: <multimedia, HDA> at device 0.1 (no driver attached)
pcib3: <ACPI PCI-PCI bridge> irq 41 at device 3.0 on pci0
pci2: <ACPI PCI bus> on pcib3
pci0: <base peripheral> at device 5.0 (no driver attached)
pci0: <base peripheral> at device 5.2 (no driver attached)
pcib4: <ACPI PCI-PCI bridge> irq 16 at device 17.0 on pci0
pci4: <ACPI PCI bus> on pcib4
pci0: <simple comms> at device 22.0 (no driver attached)
em0: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0xf040-0xf05f mem 0xfb600000-0xfb61ffff,0xfb628000-0xfb628fff irq 18 at device 25.0 on pci0
em0: Using an MSI interrupt
em0: Ethernet address: c8:60:00:cb:13:1c
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfb627000-0xfb6273ff irq 23 at device 26.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib5: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> irq 16 at device 28.1 on pci0
pci6: <ACPI PCI bus> on pcib6
ahci0: <ASMedia ASM1061 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xfb500000-0xfb5001ff irq 17 at device 0.0 on pci6
ahci0: AHCI v1.20 with 2 6Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
pcib7: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci7: <ACPI PCI bus> on pcib7
pci7: <serial bus, USB> at device 0.0 (no driver attached)
pcib8: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci8: <ACPI PCI bus> on pcib8
pci8: <serial bus, USB> at device 0.0 (no driver attached)
pcib9: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0
pci9: <ACPI PCI bus> on pcib9
siis0: <SiI3132 SATA controller> port 0xc000-0xc07f mem 0xfb284000-0xfb28407f,0xfb280000-0xfb283fff irq 16 at device 0.0 on pci9
siisch0: <SIIS channel> at channel 0 on siis0
siisch1: <SIIS channel> at channel 1 on siis0
pcib10: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0
pci10: <ACPI PCI bus> on pcib10
ahci1: <Marvell 88SE9130 AHCI SATA controller> port 0xb040-0xb047,0xb030-0xb033,0xb020-0xb027,0xb010-0xb013,0xb000-0xb00f mem 0xfb110000-0xfb1107ff irq 19 at device 0.0 on pci10
ahci1: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahci1: quirks=0x800<ALTSIG>
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
ahcich8: <AHCI channel> at channel 6 on ahci1
ahcich9: <AHCI channel> at channel 7 on ahci1
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfb626000-0xfb6263ff irq 23 at device 29.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci1
pcib11: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci11: <ACPI PCI bus> on pcib11
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci2: <Intel Patsburg AHCI SATA controller> port 0xf090-0xf097,0xf080-0xf083,0xf070-0xf077,0xf060-0xf063,0xf020-0xf03f mem 0xfb625000-0xfb6257ff irq 20 at device 31.2 on pci0
ahci2: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich10: <AHCI channel> at channel 0 on ahci2
ahcich11: <AHCI channel> at channel 1 on ahci2
ahcich12: <AHCI channel> at channel 2 on ahci2
ahcich13: <AHCI channel> at channel 3 on ahci2
ahcich14: <AHCI channel> at channel 4 on ahci2
ahcich15: <AHCI channel> at channel 5 on ahci2
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
pcib12: <ACPI Host-PCI bridge> on acpi0
pci255: <ACPI PCI bus> on pcib12
pci255: <base peripheral> at device 8.0 (no driver attached)
pci255: <base peripheral> at device 8.3 (no driver attached)
pci255: <base peripheral> at device 8.4 (no driver attached)
pci255: <base peripheral> at device 9.0 (no driver attached)
pci255: <base peripheral> at device 9.3 (no driver attached)
pci255: <base peripheral> at device 9.4 (no driver attached)
pci255: <base peripheral> at device 10.0 (no driver attached)
pci255: <base peripheral> at device 10.1 (no driver attached)
pci255: <base peripheral> at device 10.2 (no driver attached)
pci255: <base peripheral> at device 10.3 (no driver attached)
pci255: <base peripheral> at device 11.0 (no driver attached)
pci255: <base peripheral> at device 11.3 (no driver attached)
pci255: <base peripheral> at device 12.0 (no driver attached)
pci255: <base peripheral> at device 12.1 (no driver attached)
pci255: <base peripheral> at device 12.6 (no driver attached)
pci255: <base peripheral> at device 12.7 (no driver attached)
pci255: <base peripheral> at device 13.0 (no driver attached)
pci255: <base peripheral> at device 13.1 (no driver attached)
pci255: <base peripheral> at device 13.6 (no driver attached)
pci255: <base peripheral> at device 14.0 (no driver attached)
pci255: <dasp> at device 14.1 (no driver attached)
pci255: <base peripheral> at device 15.0 (no driver attached)
pci255: <base peripheral> at device 15.1 (no driver attached)
pci255: <base peripheral> at device 15.2 (no driver attached)
pci255: <base peripheral> at device 15.3 (no driver attached)
pci255: <base peripheral> at device 15.4 (no driver attached)
pci255: <base peripheral> at device 15.5 (no driver attached)
pci255: <base peripheral> at device 15.6 (no driver attached)
pci255: <base peripheral> at device 16.0 (no driver attached)
pci255: <base peripheral> at device 16.1 (no driver attached)
pci255: <base peripheral> at device 16.2 (no driver attached)
pci255: <base peripheral> at device 16.3 (no driver attached)
pci255: <base peripheral> at device 16.4 (no driver attached)
pci255: <base peripheral> at device 16.5 (no driver attached)
pci255: <base peripheral> at device 16.6 (no driver attached)
pci255: <base peripheral> at device 16.7 (no driver attached)
pci255: <base peripheral> at device 17.0 (no driver attached)
pci255: <base peripheral> at device 19.0 (no driver attached)
pci255: <dasp> at device 19.1 (no driver attached)
pci255: <dasp> at device 19.4 (no driver attached)
pci255: <dasp> at device 19.5 (no driver attached)
pci255: <base peripheral> at device 19.6 (no driver attached)
acpi_button0: <Power Button> on acpi0
ichwd0 on isa0
orm0: <ISA Option ROMs> at iomem 0xce800-0xd2fff,0xd3000-0xd5fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
p4tcc4: <CPU Frequency Thermal Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
p4tcc5: <CPU Frequency Thermal Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
p4tcc6: <CPU Frequency Thermal Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
p4tcc7: <CPU Frequency Thermal Control> on cpu7
(noperiph:siisch1:0:-1:-1): rescan already queued
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe000c260c00 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ada0 at siisch1 bus 0 scbus3 target 0 lun 0
ada0: <ST4000DM000-1F2168 CC52> ATA-8 SATA 3.x device
ada0: Serial Number Z300GYNA
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad10
ada1 at ahcich2 bus 0 scbus4 target 0 lun 0
ada1: <HGST HDS724040ALE640 MJAOA580> ATA-8 SATA 3.x device
ada1: Serial Number PK2334PBJMG1MT
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada1: Previously was known as ad12
ada2 at ahcich3 bus 0 scbus5 target 0 lun 0
ada2: <Hitachi HDS724040ALE640 MJAOA3B0> ATA-8 SATA 3.x device
ada2: Serial Number PK1310PAG5U3XJ
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada2: Previously was known as ad14
ada3 at ahcich10 bus 0 scbus12 target 0 lun 0
ada3: <Hitachi HDS724040ALE640 MJAOA250> ATA-8 SATA 3.x device
ada3: Serial Number PK2310PAG053SM
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada3: Previously was known as ad28
ada4 at ahcich11 bus 0 scbus13 target 0 lun 0
ada4: <Hitachi HDS724040ALE640 MJAOA250> ATA-8 SATA 3.x device
ada4: Serial Number PK2311PAG09ULM
ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada4: Previously was known as ad30
ada5 at ahcich12 bus 0 scbus14 target 0 lun 0
ada5: <Hitachi HDS724040ALE640 MJAOA3B0> ATA-8 SATA 3.x device
ada5: Serial Number PK1331PAGEB58S
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada5: Previously was known as ad32
ada6 at ahcich13 bus 0 scbus15 target 0 lun 0
ada6: <ST4000DM000-1F2168 CC52> ATA-8 SATA 3.x device
ada6: Serial Number Z300GQ73
ada6: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada6: Command Queueing enabled
ada6: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada6: quirks=0x1<4K>
ada6: Previously was known as ad34
ada7 at ahcich14 bus 0 scbus16 target 0 lun 0
ada7: <ST4000DM000-1F2168 CC52> ATA-8 SATA 3.x device
ada7: Serial Number Z300GZBB
ada7: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada7: Command Queueing enabled
ada7: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada7: quirks=0x1<4K>
ada7: Previously was known as ad36
ada8 at ahcich15 bus 0 scbus17 target 0 lun 0
ada8: <Hitachi HDS724040ALE640 MJAOA3B0> ATA-8 SATA 3.x device
ada8: Serial Number PK1331PAG8LHZS
ada8: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada8: Command Queueing enabled
ada8: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada8: Previously was known as ad38
pass3 at ahcich9 bus 0 scbus11 target 0 lun 0
pass3: <Marvell 91xx Config 1.01> Removable Processor SCSI-0 device
pass3: Serial Number HKDP221516WL
pass3: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
SMP: AP CPU #1 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #4 Launched!
Swap zone entries reduced from 7111631 to 4741087.
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
Root mount waiting for: usbus1 usbus0
uhub2: 6 ports with 6 removable, self powered
uhub3: 8 ports with 8 removable, self powered
ugen1.3: <Dell> at usbus1
ukbd0: <Dell Dell USB Keyboard, class 0/0, rev 1.10/3.01, addr 3> on usbus1
kbd2 at ukbd0
ugen1.4: <SMI Corporation> at usbus1
umass0: <SMI Corporation USB DISK, class 0/0, rev 2.10/11.00, addr 4> on usbus1
umass0:  SCSI over Bulk-Only; quirks = 0x4000
umass0:19:0:-1: Attached to scbus19
da0 at umass-sim0 bus 0 scbus19 target 0 lun 0
da0: <SMI USB DISK 1100> Removable Direct Access SCSI-6 device
da0: Serial Number 1114282799999999
da0: 40.000MB/s transfers
da0: 7500MB (15360000 512 byte sectors: 255H 63S/T 956C)
da0: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
ugen1.5: <vendor 0x0cf3> at usbus1
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:     Crypto: hardware
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada4p1.eli created.
GEOM_ELI: Device ada5p1.eli created.
GEOM_ELI: Device ada6p1.eli created.
GEOM_ELI: Device ada7p1.eli created.
GEOM_ELI: Device ada8p1.eli created.
GEOM_ELI: Device ada1p1.eli created.
[root@freenas] ~#
