ChrisChros
- Nov 24, 2018
I'm running FreeNAS as bear metal, specs in the signature. My Network infrastructure is a Unifi System with USG, US-48-500 PoE Switch and UAP-AC-Pro Access Points. In the USG I have setup several VLans and on the switch the SFP+ port for FreeNAS is setup as a Trunk.
In FreeNAS I have a CentOS 7.6 VM (VirtIO NIC) with a home Automation Server for my KNX System. The VM has a VLan Tagg (20) and VLan is handled in FreeNAS, I followed this instruction to set everything up. In parallel I have different Jails running, including the Unifi Controller on VLan1.
Since the installation of my 10 GbE NIC, I recognize in my Centos VM irregularly connection losses to the KNX IP Gateway (also VLan 20, tagged port in the switch) and also to another apcupsd server. In the Unifi Controller there is nothing reported about connection losses, also in FreeNAS itself.
For trouble shooting I switched over the parent interface for my VLan 20 from my 10 GbE Intel X520-DA2 to one of my on-board 1 GbE Intel NICs. Since this time the system is not recognizing any connection loss to the KNX system, whether to the apcupsd server.
Does anybody of you have an idea where these connection losses came from? Obviously it has something to do with the Intel NIC, but my research pointed out that it should run out of the box.
Regards Chris
Regards Chris
