ZVOL recommended block size
newlink
Is the ZVOL 8 kB block size the most performant option (iSCSI+ZFS) with a VMFS-5 volume?
VMFS-5 datastores use a 1MB block size and 8kB sized sub-blocks, so the default 8 kB block looks like a pretty reasonable and logical option to increase IOPS (while probably sacrificing a little bit the total data burst) but I haven't seen accurate comparative tests so far with bigger blocks (64 kB, for example) and Freenas
I leave the default and use that. In the big scheme of things, from personal experience, having hardware that can do the job is more important than setting a block size. Usually this means lots of RAM and an L2ARC.
Of course, if you do something silly like do 512byte blocks you can expect performance to take a serious nosedive.
newlink
Too big blocks are out of question, but a lot of commercial SAN use a default 64 or 128 block size, probably because the old VMFS-3 standard used a 64 kB block. How about partition aligment between different layers (LUNS -> VMware -> VM disks)? Is it important?
