michaeleino
- Jan 17, 2014
Hello All
I have a 1 RaidZ2 Vdev consists of 8x14TB+1spare Ultrastar DC HC530 "Which I don't think it is SMR"..
OS Version: FreeNAS-11.3-U4.1 --- I can't really remember.. but I think this issue appears after 11.1 or 11.2
HW:
Supermicro Model: SSG-6049P-E1CR24L
Memory: 95 GiB
NO ZIL/SLOG
disks are new, and passes the SMART short/long tests.
Tunables:
The issue with the Zvol when I do attach it to the VM, the write speed looks like a turtle ... or even slower :(
Here is the test on the dataset that contain the ZVOL ~ 380 MB/s
and here is the test from the VM which have the Zvol:
zpool status:
The guest OSs that tested are: Ubuntu 20.04.1 LTS // Ubuntu 18.04.5 LTS // Ubuntu 16.04.7 LTS // Centos 8.2
With Ubuntu18.04 i have tried kernel v3.18-generic // v4.12-generic // v4.4-generic // 4.15-generic // 4.15-generic-hwe // v5.4-generic-hwe
I've read most available posts about VMs and Zvol as a block... but I beleive it should not be dead like this!
even the delay/tolreance of bhyve should not kill the performance like this.
earlier on an old system I was using a PC with 16GB-nonECC ram and desktop HDDs with freenas 9.x and Vbox jail ... and it was totally totally awesome !
What should I check!? I'm really hitting the walls
Thanks in advance.
HW:
Memory: 95 GiB
NO ZIL/SLOG
Tunables:
kern.ipc.maxsockbuf 8388608 kern.ipc.nmbclusters 6042656 vfs.zfs.l2arc_norw 0 vfs.zfs.l2arc_write_boost 40000000 vfs.zfs.l2arc_write_max 10000000 vfs.zfs.metaslab.lba_weighting_enabled 1 vfs.zfs.zfetch.max_distance 33554432 vfs.zfs.arc_max 51431000000
root@fn[/mnt/superstorage/VMs]# iozone –Ra –g 1G –i 0 –i 1 -+u -+r
Iozone: Performance Test of File I/O
Version $Revision: 3.487 $
Compiled for 64 bit mode.
Build: freebsd
Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
Al Slater, Scott Rhine, Mike Wisner, Ken Goss
Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,
Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,
Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,
Vangel Bojaxhi, Ben England, Vikentsi Lapa,
Alexey Skidanov, Sudhir Kumar.
Run began: Sun Sep 13 22:10:41 2020
Command line used: iozone –Ra –g 1G –i 0 –i 1 -+u -+r
Output is in kBytes/sec
Time Resolution = 0.000001 seconds.
Processor cache size set to 1024 kBytes.
Processor cache line size set to 32 bytes.
File stride size set to 17 * record size.
random random bkwd record stride
kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
512 4 377891 610287 1688531 1895721 1624659 675563 1355045 701378 1312798 701378 653961 1442420 1695195
iozone test complete.
root@fn[/mnt/superstorage/VMs]# iozone –Ra –g 2G –i 0 –i 1 -+u -+r
Build: freebsd
Run began: Sun Sep 13 22:10:54 2020
Command line used: iozone –Ra –g 2G –i 0 –i 1 -+u -+r
512 4 367858 576535 1931527 2089386 1662389 606667 1426135 669247 1365383 673655 615359 1147892 1835760
iozone test complete.and here is the test from the VM which have the Zvol:
root@guest:~# iozone –Ra –g 1G –i 0 –i 1 -+u -+r
Version $Revision: 3.429 $
Build: linux-AMD64
Vangel Bojaxhi, Ben England, Vikentsi Lapa.
Run began: Sun Sep 13 21:41:30 2020
CPU utilization Resolution = 0.000 seconds.
CPU utilization Excel chart enabled
Read & Write sync mode active.
Command line used: iozone -+u -+r –Ra –g 1G –i 0 –i 1
512 4 11 9 2668325 2474613 1778004 9 1723770 10 1760512 1319250 1252318 2317080 2486072
root@guest:~# iozone –Ra –g 2G –i 0 –i 1 -+u -+r
Build: linux-AMD64
Run began: Sun Sep 13 20:46:05 2020
Command line used: iozone -+u -+r –Ra –g 2G –i 0 –i 1
512 4 11 11 1451192 1954379 2001745 8 1459080 13 1451192 1155924 939486 2207515 1924603
iozone test complete.zpool status:
root@fn[/mnt/superstorage/VMs]# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:05:05 with 0 errors on Sun Sep 13 03:50:05 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
da9p2 ONLINE 0 0 0
da10p2 ONLINE 0 0 0
errors: No known data errors
pool: superstorage
state: ONLINE
scan: scrub repaired 0 in 8 days 23:29:20 with 0 errors on Mon Sep 7 23:30:19 2020
superstorage ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/10b1bad4-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
gptid/12161a32-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
gptid/139575f0-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
gptid/14df717c-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
gptid/162e05ae-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
gptid/179149fb-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
gptid/18dc05c9-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
gptid/1a2602eb-ad3f-11e9-887d-ac1f6b751d78 ONLINE 0 0 0
spares
gptid/1b7a2947-ad3f-11e9-887d-ac1f6b751d78 AVAIL
https://www.ixsystems.com/community/threads/optimal-zvol-configuration-for-debian-vm-guests-performance.84556/ https://www.ixsystems.com/community/threads/the-path-to-success-for-block-storage.81165/
Thanks in advance.
