ZPS Pool Does Not Mount After Reboot
xioustic
Hey guys,
Every time I reboot my FreeNAS server, its ZFS pool 'tank' doesn't mount and becomes faulted. However, all the disks that the pool depend on have not been shifted or had cables changed since the last time it was functioning.
The pool consists of six drives in RAIDZ2 configuration. The drives are mixed/matched manufacturers, rpm, etc and half are 3TB, the other half are 4TB. I will eventually replace all the 3TB with 4TB to expand the pool.
This was initially immediately alarming, but after detaching the missing pool in the GUI and then hitting auto-import, the pool popped back up and imported fine (all data intact). I then recreated my CIFS shares and my scrubbing schedule. All the SMART scheduling remains intact for the drives through a restart.
After rebooting again later, the same issue arose and it became clear this would be a recurring problem. No data loss is apparent and auto-importing works fine, but I *do* want to install some jails on this machine and I'm assuming that those services will depend on the pool being available at restart.
I will follow up shortly with all the relevant outputs I can think of to assist with diagnosing the issue. I could not put it in my main post as the output exceeds the 30,000 character limit.
The only other thing I could think of is that as the machine boots, I recall FreeNAS initializing and mentioning something along the lines of "cannot create pool <long integer>, already exists" and then later in the initialization process "cannot find pool 'tank'" and/or "cannot create pool tank, already exists". I can not pin down the error message as it happens during the boot process on the monitor; I do not see it in dmesg output as I thought I should expect.
I *could* reformat FreeNAS onto a new USB drive and try starting over by auto-importing the pool, but I hate to redo all my short/long/zscrub scheduling as well as my SMTP settings and whatnot. It wouldn't be the end of the world though.
My main concern is about losing my data, and I know nothing beats a good backup. My ISP gets pretty mad if I try to copy the 6 TB of data offsite though, and that takes a ton of time and simply isn't practical for the immediate time being.
In the meantime, I'll just try to keep the machine from ever having to be rebooted.
Thanks for any help anyone can provide.
xioustic
After boot diagnostics:
GUI disk list at boot
GUI volume list at boot
GUI pool status at boot
'zpool status' at boot (pool has failed)
[root@freenas] ~# zpool status
  pool: tank
 state: UNAVAIL
status: One or more devices could not be opened.  There are insufficient
        replicas for the pool to continue functioning.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-3C
  scan: none requested
        NAME                      STATE     READ WRITE CKSUM
        tank                      UNAVAIL      0     0     0
          raidz2-0                UNAVAIL      0     0     0
            5168377097152573575   OFFLINE      0     0     0  was /zfs1
            10828644092830937624  UNAVAIL      0     0     0  was /dev/ada1
            15015675742944419408  UNAVAIL      0     0     0  was /dev/ada2
            6956502727329578853   UNAVAIL      0     0     0  was /dev/ada3
            12218151412645146773  UNAVAIL      0     0     0  was /dev/ada4
            2435771696198351240   UNAVAIL      0     0     0  was /dev/ada0
'camcontrol devlist' at boot (drives are found)
[root@freenas] ~# camcontrol devlist
<WDC WD40EZRX-00SPEB0 80.00A80>    at scbus0 target 0 lun 0 (ada0,pass0)
<ST4000DM000-1F2168 CC54>          at scbus1 target 0 lun 0 (ada1,pass1)
<ST4000DM000-1F2168 CC52>          at scbus2 target 0 lun 0 (ada2,pass2)
<ST3000DM001-9YN166 CC4B>          at scbus3 target 0 lun 0 (ada3,pass3)
<WDC WD30EZRX-00SPEB0 80.00A80>    at scbus4 target 0 lun 0 (ada4,pass4)
<Marvell Console 1.01>             at scbus9 target 0 lun 0 (pass5)
<ST3000DM001-9YN166 CC4B>          at scbus13 target 0 lun 0 (ada5,pass6)
<SanDisk Cruzer 1.02>              at scbus17 target 0 lun 0 (pass7,da0)
'zpool list' at boot (no pool?)
[root@freenas] ~# zpool list
NAME   SIZE  ALLOC   FREE    CAP  DEDUP  HEALTH  ALTROOT
tank      -      -      -      -      -  FAULTED  -
'gpart list' at boot
[root@freenas] ~# gpart list
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7813971599
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: a614bf9a-31a6-11e4-b5b6-d050991b63e9
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada0p2
   Mediasize: 3998605905920 (3.7T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: a625d53a-31a6-11e4-b5b6-d050991b63e9
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 3998605905920
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7813971591
   start: 4194432
Consumers:
1. Name: ada0
   Mediasize: 4000753476096 (3.7T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7814037134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 3e5990b6-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada1p2
   Mediasize: 3998639460352 (3.7T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 3e6ab1ea-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   length: 3998639460352
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037127
   start: 4194432
Consumers:
1. Name: ada1
   Mediasize: 4000787030016 (3.7T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7814037134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 5d8592db-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada2p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 5d939f80-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037127
   start: 4194432
Consumers:
1. Name: ada2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 73aaeed8-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada3p2
   Mediasize: 2998445412352 (2.7T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 73c6ce39-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   length: 2998445412352
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 5860533127
   start: 4194432
Consumers:
1. Name: ada3
   Mediasize: 3000592982016 (2.7T)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: ada4
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada4p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 84dd091d-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada4p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 84f56ffb-31a6-11e4-b5b6-d050991b63e9
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 5860533127
   start: 4194432
Consumers:
1. Name: ada4
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: ada5
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada5p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   rawuuid: 1a651fa0-3664-11e4-898e-d050991b63e9
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada5p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   rawuuid: 1a849e65-3664-11e4-898e-d050991b63e9
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 5860533127
   start: 4194432
Consumers:
1. Name: ada5
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15625215
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: da0s1
   Mediasize: 988291584 (942M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 32256
   Mode: r1w0e1
   attrib: active
   rawtype: 165
   length: 988291584
   offset: 32256
   type: freebsd
   index: 1
   end: 1930319
   start: 63
2. Name: da0s2
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 988356096
   Mode: r0w0e0
   rawtype: 165
   length: 988291584
   offset: 988356096
   type: freebsd
   index: 2
   end: 3860639
   start: 1930383
3. Name: da0s3
   Mediasize: 1548288 (1.5M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 1976647680
   Mode: r0w0e0
   rawtype: 165
   length: 1548288
   offset: 1976647680
   type: freebsd
   index: 3
   end: 3863663
   start: 3860640
4. Name: da0s4
   Mediasize: 21159936 (20M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 1978195968
   Mode: r1w1e2
   rawtype: 165
   length: 21159936
   offset: 1978195968
   type: freebsd
   index: 4
   end: 3904991
   start: 3863664
Consumers:
1. Name: da0
   Mediasize: 8000110592 (7.5G)
   Sectorsize: 512
   Mode: r2w1e4
Geom name: da0s1
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: da0s1a
   Mediasize: 988283392 (942M)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 40448
   Mode: r1w0e1
   rawtype: 0
   length: 988283392
   offset: 8192
   type: !0
   index: 1
   end: 1930256
   start: 16
Consumers:
1. Name: da0s1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 32256
   Mode: r1w0e1
'dmesg' output at boot
[root@freenas] ~# dmesg
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.2-RELEASE-p10 #0 r262572+4fb5adc: Wed Aug  6 17:07:16 PDT 2014
    root@build3.ixsystems.com:/fusion/jkh/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Atom(TM) CPU  C2750  @ 2.40GHz (2400.14-MHz K8-class CPU)
  Origin = "GenuineIntel"  Id = 0x406d8  Family = 0x6  Model = 0x4d  Stepping = 8
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x43d8e3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,RDRAND>
  AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
  AMD Features2=0x101<LAHF,Prefetch>
  Standard Extended Features=0x2282<TSCADJ,SMEP,ENHMOVSB>
  TSC: P-state invariant, performance statistics
real memory  = 17179869184 (16384 MB)
avail memory = 16474034176 (15710 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <INTEL  TIANO   >
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 8 core(s)
 cpu0 (BSP): APIC ID:  0
 cpu1 (AP): APIC ID:  2
 cpu2 (AP): APIC ID:  4
 cpu3 (AP): APIC ID:  6
 cpu4 (AP): APIC ID:  8
 cpu5 (AP): APIC ID: 10
 cpu6 (AP): APIC ID: 12
 cpu7 (AP): APIC ID: 14
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320)
ACPI Warning: Invalid length for Pm1aControlBlock: 32, using default 16 (20110527/tbfadt-638)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS> on motherboard
padlock0: No ACE support.
acpi0: <ALASKA A M I > on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 450
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> mem 0xdf740000-0xdf75ffff irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> mem 0xdf720000-0xdf73ffff irq 20 at device 3.0 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> mem 0xdf500000-0xdf51ffff irq 22 at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
pcib4: <PCI-PCI bridge> irq 23 at device 1.0 on pci3
pci4: <PCI bus> on pcib4
ahci0: <Marvell 88SE9172 AHCI SATA controller> port 0xc040-0xc047,0xc030-0xc033,0xc020-0xc027,0xc010-0xc013,0xc000-0xc00f mem 0xdf410000-0xdf4101ff irq 23 at device 0.0 on pci4
ahci0: AHCI v1.00 with 2 6Gbps ports, Port Multiplier supported with FBS
ahci0: quirks=0x100<NOBSYRES>
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
pcib5: <PCI-PCI bridge> irq 23 at device 5.0 on pci3
pci5: <PCI bus> on pcib5
pcib6: <PCI-PCI bridge> irq 23 at device 0.0 on pci5
pci6: <PCI bus> on pcib6
vgapci0: <VGA-compatible display> port 0xb000-0xb07f mem 0xde000000-0xdeffffff,0xdf000000-0xdf01ffff irq 23 at device 0.0 on pci6
pcib7: <PCI-PCI bridge> irq 21 at device 7.0 on pci3
pci7: <PCI bus> on pcib7
igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0xa000-0xa01f mem 0xdf300000-0xdf37ffff,0xdf380000-0xdf383fff irq 21 at device 0.0 on pci7
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: d0:50:99:1b:63:e9
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib8: <PCI-PCI bridge> irq 23 at device 9.0 on pci3
pci8: <PCI bus> on pcib8
igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x9000-0x901f mem 0xdf200000-0xdf27ffff,0xdf280000-0xdf283fff irq 23 at device 0.0 on pci8
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: d0:50:99:1b:63:ea
igb1: Bound queue 0 to cpu 4
igb1: Bound queue 1 to cpu 5
igb1: Bound queue 2 to cpu 6
igb1: Bound queue 3 to cpu 7
pcib9: <ACPI PCI-PCI bridge> mem 0xdf700000-0xdf71ffff at device 4.0 on pci0
pci9: <ACPI PCI bus> on pcib9
ahci1: <Marvell 88SE9230 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xdf610000-0xdf6107ff irq 23 at device 0.0 on pci9
ahci1: AHCI v1.20 with 8 6Gbps ports, Port Multiplier not supported
ahci1: quirks=0x800<ALTSIG>
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
ahcich8: <AHCI channel> at channel 6 on ahci1
ahcich9: <AHCI channel> at channel 7 on ahci1
pci0: <base peripheral> at device 15.0 (no driver attached)
pci0: <base peripheral> at device 19.0 (no driver attached)
ehci0: <Intel Avoton USB 2.0 controller> mem 0xdf763000-0xdf7633ff irq 23 at device 22.0 on pci0
usbus0: EHCI version 1.0
usbus0 on ehci0
ahci2: <Intel Avoton AHCI SATA controller> port 0xe0d0-0xe0d7,0xe0c0-0xe0c3,0xe0b0-0xe0b7,0xe0a0-0xe0a3,0xe040-0xe05f mem 0xdf762000-0xdf7627ff irq 19 at device 23.0 on pci0
ahci2: AHCI v1.30 with 4 3Gbps ports, Port Multiplier not supported
ahcich10: <AHCI channel> at channel 0 on ahci2
ahcich11: <AHCI channel> at channel 1 on ahci2
ahcich12: <AHCI channel> at channel 2 on ahci2
ahcich13: <AHCI channel> at channel 3 on ahci2
ahci3: <Intel Avoton AHCI SATA controller> port 0xe090-0xe097,0xe080-0xe083,0xe070-0xe077,0xe060-0xe063,0xe020-0xe03f mem 0xdf761000-0xdf7617ff irq 19 at device 24.0 on pci0
ahci3: AHCI v1.30 with 2 6Gbps ports, Port Multiplier not supported
ahcich14: <AHCI channel> at channel 0 on ahci3
ahcich15: <AHCI channel> at channel 1 on ahci3
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart2: <16550 or compatible> port 0x248-0x24f irq 3 on acpi0
orm0: <ISA Option ROM> at iomem 0xc0000-0xc7fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
fdc0: <Enhanced floppy controller> at port 0x3f0-0x3f5,0x3f7 irq 6 drq 2 on isa0
wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
p4tcc4: <CPU Frequency Thermal Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
p4tcc5: <CPU Frequency Thermal Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
p4tcc6: <CPU Frequency Thermal Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
p4tcc7: <CPU Frequency Thermal Control> on cpu7
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe0008351c80 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
usbus0: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD40EZRX-00SPEB0 80.00A80> ATA-9 SATA 3.x device
ada0: Serial Number WD-WCC4ERRR5R07
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 3815415MB (7813971633 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <ST4000DM000-1F2168 CC54> ATA-9 SATA 3.x device
ada1: Serial Number S300PXXX
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <ST4000DM000-1F2168 CC52> ATA-8 SATA 3.x device
ada2: Serial Number W300RMQL
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 3815447MB (7814037168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada2: Previously was known as ad8
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <ST3000DM001-9YN166 CC4B> ATA-8 SATA 3.x device
ada3: Serial Number W1F190A2
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad10
ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
ada4: <WDC WD30EZRX-00SPEB0 80.00A80> ATA-9 SATA 3.x device
ada4: Serial Number WD-WCC4EC6HJN7F
ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada4: quirks=0x1<4K>
ada4: Previously was known as ad12
ada5 at ahcich13 bus 0 scbus13 target 0 lun 0
ada5: <ST3000DM001-9YN166 CC4B> ATA-8 SATA 3.x device
ada5: Serial Number W1F1AB4C
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada5: quirks=0x1<4K>
ada5: Previously was known as ad30
pass5 at ahcich9 bus 0 scbus9 target 0 lun 0
pass5: <Marvell Console 1.01> Removable Processor SCSI-0 device
pass5: Serial Number HKDP221516WL
pass5: 150.000MB/s transfers (SATA 1.x, UDMA4, ATAPI 12bytes, PIO 8192bytes)
SMP: AP CPU #1 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #5 Launched!
Timecounter "TSC-low" frequency 1200071556 Hz quality 1000
uhub0: 8 ports with 8 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub1: <vendor 0x8087 product 0x07db, class 9/0, rev 2.00/0.02, addr 2> on usbus0
uhub1: 4 ports with 4 removable, self powered
Root mount waiting for: usbus0
ugen0.3: <SanDisk> at usbus0
umass0: <SanDisk Cruzer, class 0/0, rev 2.00/1.00, addr 3> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0x4100
umass0:17:0:-1: Attached to scbus17
da0 at umass-sim0 bus 0 scbus17 target 0 lun 0
da0: <SanDisk Cruzer 1.02> Removable Direct Access SCSI-2 device
da0: Serial Number 20040202801DCFF1989A
da0: 40.000MB/s transfers
da0: 7629MB (15625216 512 byte sectors: 255H 63S/T 972C)
da0: quirks=0x2<NO_6_BYTE>
ugen0.4: <American Megatrends Inc.> at usbus0
uhub2: <7-port Hub> on usbus0
uhub2: 5 ports with 5 removable, self powered
ugen0.5: <American Megatrends Inc.> at usbus0
ukbd0: <Keyboard Interface> on usbus0
kbd2 at ukbd0
ums0: <Mouse Interface> on usbus0
ums0: 3 buttons and [Z] coordinates ID=0
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:     Crypto: hardware
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada4p1.eli created.
GEOM_ELI: Device ada5p1.eli created.
vboxdrv: fAsync=0 offMin=0x690 offMax=0x1188
xioustic
After detach and auto-import (all functional) diagnostics:
GUI disk list after detach and auto-import
GUI volume list after detach and auto-import
GUI pool status after detach and auto-import
'zpool status' after detach and auto-import in GUI
  pool: tank
 state: ONLINE
  scan: resilvered 1.41T in 6h45m with 0 errors on Sun Sep  7 07:39:28 2014
        tank                                            ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/1a849e65-3664-11e4-898e-d050991b63e9  ONLINE       0     0     0
            gptid/5d939f80-31a6-11e4-b5b6-d050991b63e9  ONLINE       0     0     0
            gptid/73c6ce39-31a6-11e4-b5b6-d050991b63e9  ONLINE       0     0     0
            gptid/84f56ffb-31a6-11e4-b5b6-d050991b63e9  ONLINE       0     0     0
            gptid/a625d53a-31a6-11e4-b5b6-d050991b63e9  ONLINE       0     0     0
            gptid/3e6ab1ea-31a6-11e4-b5b6-d050991b63e9  ONLINE       0     0     0
errors: No known data errors
'camcontrol devlist' after detach and auto-import in GUI
'zpool list' after detach and auto-import in GUI
tank  16.2T  8.52T  7.73T    52%  1.00x  ONLINE  /mnt
Geom name: ada0
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7813971599
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada0p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada0p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7813971591
   start: 4194432
Consumers:
1. Name: ada0
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: ada1
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7814037134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada1p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada1p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037127
   start: 4194432
Consumers:
1. Name: ada1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: ada2
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 7814037134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada2p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 7814037127
   start: 4194432
Consumers:
1. Name: ada2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: ada3
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada3p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 5860533127
   start: 4194432
Consumers:
1. Name: ada3
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: ada4
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada4p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada4p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 5860533127
   start: 4194432
Consumers:
1. Name: ada4
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: ada5
modified: false
state: OK
fwheads: 16
fwsectors: 63
last: 5860533134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada5p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada5p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
   label: (null)
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 5860533127
   start: 4194432
Consumers:
1. Name: ada5
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r2w2e5
Geom name: da0
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 15625215
first: 63
entries: 4
scheme: MBR
Providers:
1. Name: da0s1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 32256
   Mode: r1w0e1
   attrib: active
   rawtype: 165
   length: 988291584
   offset: 32256
   type: freebsd
   index: 1
   end: 1930319
   start: 63
2. Name: da0s2
   Sectorsize: 512
   Stripesize: 0
   Mode: r0w0e0
   rawtype: 165
   length: 988291584
   offset: 988356096
   type: freebsd
   index: 2
   end: 3860639
   start: 1930383
3. Name: da0s3
   Sectorsize: 512
   Stripesize: 0
   Mode: r0w0e0
   rawtype: 165
   length: 1548288
   offset: 1976647680
   type: freebsd
   index: 3
   end: 3863663
   start: 3860640
4. Name: da0s4
   Sectorsize: 512
   Stripesize: 0
   Mode: r1w1e2
   rawtype: 165
   length: 21159936
   offset: 1978195968
   type: freebsd
   index: 4
   end: 3904991
   start: 3863664
Consumers:
1. Name: da0
   Sectorsize: 512
   Mode: r2w1e4
Geom name: da0s1
modified: false
state: OK
fwheads: 255
fwsectors: 63
last: 1930256
first: 0
entries: 8
scheme: BSD
Providers:
1. Name: da0s1a
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 40448
   Mode: r1w0e1
   rawtype: 0
   length: 988283392
   offset: 8192
   type: !0
   index: 1
   end: 1930256
   start: 16
Consumers:
1. Name: da0s1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 32256
   Mode: r1w0e1
'dmesg' output after detach and auto-import in GUI
kbd1 at kbdmux0
usbus0 on ehci0
kbd0 at atkbd0
kbd2 at ukbd0
anodos
Sambassador
Please give detailed list of hardware in computer including:
  • Motherboard
  • RAM
  • How drives are connected (directly to mobo, through SATA port multiplier, etc.)
Make sure you have a backup - even if it's just data copied to a few USB drives. I don't understand why your ISP is an issue. You have physical access to your server, correct?
xioustic
The ISP throttles the connection past 250 GB of upload+download per month. I have 6 TB of data total to back up for the array to Crashplan. So it'll be about 4 years before this all gets backed up off-site. The logistics of downloading it back are silly to think about as well. There are no ISPs in my area that do not follow this practice of rate limiting and capping bandwidth.
I do not have 6 TB worth of available external / alternate drives to mirror the data set on.
MOBO: ASRock C27450D4I
RAM: Crucial 16GB Kit (8GBx2) DDR3L 1600MT/s (PC3-12800) DR x8 ECC UDIMM 240-Pin Server Memory CT2KIT102472BD160B
Drives: All six drives connected to Mobo directly; FreeNAS USB drive plugged directly to Motherboard USB Socket
I have circled where on the Motherboard everything is plugged in:
krikboh
Was the pool created in FreeNAS through the GUI?
xioustic
The pool was originally created using the 'zpool' commands on the CLI of another machine. The drives of that original pool have all since been replaced using the GUI of FreeNAS after auto-importing the array initially.
anodos
Sambassador
Cloud backup is clearly not an option for you. Honestly, it's not an option for me either. I keep my backups in a fire-proof safe in my house. Not to be a stick in the mud, but 6TB of storage isn't impossibly expensive these days. Not having a backup is fundamentally a larger - though not as noticeable - problem.
krikboh
It's good you're disks have the proper partitioning scheme, but you can see under the pool status they are not being listed with the proper gptid labeling, that is probably the issue. You probably have no choice but to backup and recreate the pool within the GUI.
mjws00
Since your pool re-imports fine. Pull your existing FreeNAS usb. Install a fresh clean image on another stick auto-import and test. If your pool behaves normally across reboots you may be able to rule out having to rebuild your pool. You can still revert to your other USB and config and troubleshoot with a 'safe' pool etc to reduce risk. If it fails your tests on a fresh install unfortunately you are looking at a pool problem, probably requiring a rebuild, and or significant risk to fix. I'd spend the money on a couple 4TB drives use them as a backup and then an excuse to increase the size of my drives in the pool early.
Obviously depends on the value of your data, and the budget. If backups are not feasible at all, I might see if it runs great across reboots etc on freebsd, or another 'raw' flavor of zfs. Might get you by until you have a larger margin of safety and funds to deal with the pool? Unfortunately everything becomes a trade-off.
Just two bits. I'd even weigh backing up across the wire (local) to non-zfs. vs installing the drives locally and replication for full sata speeds on your pool backup. Still that piece of me that likes being able to throw drives in any old windows box and immediately access my data ;).
Good luck, maybe someone will spot a fix.
xioustic
Turns out the solution was just redoing the FreeNAS image onto a new USB from scratch and then importing the pool. I has to reconfigure FreeNAS again (a bit of a pain), but after a reboot the pool persists through and everything seems healthy.
I'm not exactly sure what went wrong; maybe I mounted the pool manually at some point in the FreeNAS CLI? Or did some tinkering with the 'zpool' commands where I shouldn't have been on this copy of FreeNAS? I'm still stumped.
Still, glad to have this solved.
jgreco
Resident Grinch
FreeNAS is highly appliance-oriented and expects that it is doing the manipulations on your pool. You can go under the hood and do lots of stuff from CLI, but you have to be aware that the system won't always be aware of those changes, and then won't respond properly on reboot.
