zpool not working in jail
Semus
Please tell me how you can install the docker in the yail (freeNAS 9,10). I have a lot of containers that need to be placed in this jail. I made a jail. I'm root. I enter the following commands:
# pkg install docker-freebsd ca_root_nss
# dd if=/dev/zero of=/usr/local/dockerfs bs=1024K count=4000
# zpool create -f pool /usr/local/dockerfs
Reply:
cannot create 'pool': permission denied
Why "permission denied"? How to fix it?
D
dlavigne
Guest
I think you want to create a dataset using Volume Manager then Add Storage in the jail that points that dataset to /usr/local/dockerfs.
Semus
Yes. I want that in JAIL there will be a device of "pool"
Then I execute the command:
zfs create -o mountpoint=/usr/docker zroot/docker
And mount the device. How can I get rid of the problem with permissions?
D
dlavigne
Guest
Which how-to are you following? I'm pretty sure you instead have to make a dataset (or perhaps a zvol) in Volume Manager and point a storage to it...
