zpool import crashes system
pixel_punk
Hallo everyone!
when deleting a jail in the GUI the server suddenly crashed and rebooted.
When it came up again I tried to unlock my encrypted pool as usual which led to another unexpected reboot.
So I logged in via SSH and tried to manually unlock the devices and import the pool.
Following this guide I successfully attached all devices:
root@strider:~ # geli status
                                          Name  Status  Components
                              mirror/swap0.eli  ACTIVE  mirror/swap0
                              mirror/swap1.eli  ACTIVE  mirror/swap1
gptid/d63b9408-6fbc-11ea-b276-3cecef01a2a0.eli  ACTIVE  gptid/d63b9408-6fbc-11ea-b276-3cecef01a2a0
gptid/d59ddc7f-6fbc-11ea-b276-3cecef01a2a0.eli  ACTIVE  gptid/d59ddc7f-6fbc-11ea-b276-3cecef01a2a0
gptid/d5031800-6fbc-11ea-b276-3cecef01a2a0.eli  ACTIVE  gptid/d5031800-6fbc-11ea-b276-3cecef01a2a0
gptid/d471a910-6fbc-11ea-b276-3cecef01a2a0.eli  ACTIVE  gptid/d471a910-6fbc-11ea-b276-3cecef01a2a0
But zpool import tank crashed the system again with this output:
So I followed these threads/posts:
Using ECC RAM this should not be a faulty module problem...
The partitions look good:
root@strider:~ # gpart status
ada0p1      OK  ada0
ada0p2      OK  ada0
ada1p1      OK  ada1
ada1p2      OK  ada1
ada2p1      OK  ada2
ada2p2      OK  ada2
ada3p1      OK  ada3
ada3p2      OK  ada3
ada4p1      OK  ada4
ada4p2      OK  ada4
But this doesn't:
root@strider:~ # zdb -e -bcsvL tank
Traversing all blocks to verify checksums ...
Assertion failed: (blkptr at 0x80b01eb80 has invalid TYPE 98), file (null), line 0.
Abort (core dumped)
Also zpool import -F tank (as suggested by Oracle) produces another system crash:
But I managed to import the pool read-only zpool import -F -f -o readonly=on -R /mnt tank...woohoo!
And it looks good:
root@strider:~ # zpool status -v tank
  pool: tank
 state: ONLINE
  scan: none requested
    NAME                                                STATE     READ WRITE CKSUM
    tank                                                ONLINE       0     0     0
      raidz1-0                                          ONLINE       0     0     0
        gptid/d471a910-6fbc-11ea-b276-3cecef01a2a0.eli  ONLINE       0     0     0
        gptid/d5031800-6fbc-11ea-b276-3cecef01a2a0.eli  ONLINE       0     0     0
        gptid/d59ddc7f-6fbc-11ea-b276-3cecef01a2a0.eli  ONLINE       0     0     0
        gptid/d63b9408-6fbc-11ea-b276-3cecef01a2a0.eli  ONLINE       0     0     0
errors: No known data errors
So it seems that there is something wrong when importing that pool as RW.
Has anyone an idea what went wrong and how to fix it? I really don't want to pull 20TB from backup :o
System info:
FreeNAS-11.2-U8
Supermicro A2SDi-8C+-HLN4F
64GB DDR4-2400 regECC RAM
4x 8TB WD80EFAX-68KNBN0 (pool)
1x 250GB Samsung 860 EVO (boot)
root@strider:~ # zpool history -i tank
History for 'tank':
2020-03-27.00:52:23 [txg:5] create pool version 5000; software version 5000/5; uts strider.local 11.2-STABLE 1102500 amd64
2020-03-27.00:52:23 [txg:5] set tank (21) compression=15
2020-03-27.00:52:23 [txg:5] set tank (21) aclmode=3
2020-03-27.00:52:23 [txg:5] set tank (21) aclinherit=3
2020-03-27.00:52:23 [txg:5] set tank (21) mountpoint=/tank
2020-03-27.00:52:23 zpool create -o cachefile=/data/zfs/zpool.cache -o failmode=continue -o autoexpand=on -O compression=lz4 -O aclmode=passthrough -O aclinherit=passthrough -f -m /tank -o altroot=/mnt tank raidz /dev/gptid/d471a910-6fbc-11ea-b276-3cecef01a2a0.eli /dev/gptid/d5031800-6fbc-11ea-b276-3cecef01a2a0.eli /dev/gptid/d59ddc7f-6fbc-11ea-b276-3cecef01a2a0.eli /dev/gptid/d63b9408-6fbc-11ea-b276-3cecef01a2a0.eli
2020-03-27.00:52:23 [txg:7] inherit tank (21) mountpoint=/
2020-03-27.00:52:28 zfs inherit mountpoint tank
2020-03-27.00:52:28 zpool set cachefile=/data/zfs/zpool.cache tank
2020-04-29.13:53:57 zfs destroy -d tank/iocage/jails/plex@auto-20200405.0428-2w
2020-04-29.16:19:33 [txg:869679] destroy tank/iocage/jails/plex/root@auto-20200421.0428-2w (395)
2020-04-29.16:19:33 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200421.0428-2w
2020-04-29.16:19:33 [txg:869680] destroy tank/iocage/jails/plex/root@auto-20200425.0428-2w (465)
2020-04-29.16:19:33 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200425.0428-2w
2020-04-29.16:19:33 [txg:869681] destroy tank/iocage/jails/plex/root@auto-20200429.0428-2w (579)
2020-04-29.16:19:33 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200429.0428-2w
2020-04-29.16:19:33 [txg:869682] destroy tank/iocage/jails/plex/root@auto-20200417.0428-2w (282)
2020-04-29.16:19:33 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200417.0428-2w
2020-04-29.16:19:33 [txg:869683] destroy tank/iocage/jails/plex/root@auto-20200416.0428-2w (264)
2020-04-29.16:19:34 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200416.0428-2w
2020-04-29.16:19:34 [txg:869684] destroy tank/iocage/jails/plex/root@auto-20200428.0428-2w (550)
2020-04-29.16:19:34 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200428.0428-2w
2020-04-29.16:19:34 [txg:869685] destroy tank/iocage/jails/plex/root@auto-20200420.0428-2w (350)
2020-04-29.16:19:35 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200420.0428-2w
2020-04-29.16:19:35 [txg:869686] destroy tank/iocage/jails/plex/root@auto-20200424.0428-2w (446)
2020-04-29.16:19:35 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200424.0428-2w
2020-04-29.16:19:35 [txg:869687] destroy tank/iocage/jails/plex/root@ioc_plugin_update_2019-10-07 (384)
2020-04-29.16:19:35 <iocage> zfs destroy tank/iocage/jails/plex/root@ioc_plugin_update_2019-10-07
2020-04-29.16:19:35 [txg:869688] destroy tank/iocage/jails/plex/root@auto-20200418.0428-2w (300)
2020-04-29.16:19:35 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200418.0428-2w
2020-04-29.16:19:35 [txg:869689] destroy tank/iocage/jails/plex/root@auto-20200422.0428-2w (410)
2020-04-29.16:19:35 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200422.0428-2w
2020-04-29.16:19:35 [txg:869690] destroy tank/iocage/jails/plex/root@auto-20200426.0428-2w (486)
2020-04-29.16:19:36 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200426.0428-2w
2020-04-29.16:19:36 [txg:869691] destroy tank/iocage/jails/plex/root@ioc_update_11.2-RELEASE-p6 (373)
2020-04-29.16:19:38 <iocage> zfs destroy tank/iocage/jails/plex/root@ioc_update_11.2-RELEASE-p6
2020-04-29.16:19:38 [txg:869693] destroy tank/iocage/jails/plex/root@auto-20200423.0428-2w (430)
2020-04-29.16:19:39 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200423.0428-2w
2020-04-29.16:19:39 [txg:869695] destroy tank/iocage/jails/plex/root@auto-20200427.0428-2w (515)
2020-04-29.16:19:40 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200427.0428-2w
2020-04-29.16:19:40 [txg:869696] destroy tank/iocage/jails/plex/root@auto-20200419.0428-2w (320)
2020-04-29.16:19:42 <iocage> zfs destroy tank/iocage/jails/plex/root@auto-20200419.0428-2w
2020-04-29.16:19:44 [txg:869700] destroy tank/iocage/jails/plex/root (369)
2020-04-29.16:19:46 <iocage> zfs destroy tank/iocage/jails/plex/root
2020-04-29.16:19:46 [txg:869702] destroy tank/iocage/jails/plex@auto-20200428.0428-2w (767)
2020-04-29.16:19:48 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200428.0428-2w
2020-04-29.16:19:48 [txg:869704] destroy tank/iocage/jails/plex@auto-20200420.0428-2w (669)
2020-04-29.16:19:50 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200420.0428-2w
2020-04-29.16:19:50 [txg:869706] destroy tank/iocage/jails/plex@auto-20200424.0428-2w (720)
2020-04-29.16:19:53 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200424.0428-2w
2020-04-29.16:19:53 [txg:869708] destroy tank/iocage/jails/plex@auto-20200416.0428-2w (597)
2020-04-29.16:19:55 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200416.0428-2w
2020-04-29.16:19:55 [txg:869710] destroy tank/iocage/jails/plex@manual-20200413_movingto_beta-branche (1059)
2020-04-29.16:19:57 <iocage> zfs destroy tank/iocage/jails/plex@manual-20200413_movingto_beta-branche
2020-04-29.16:19:57 [txg:869712] destroy tank/iocage/jails/plex@auto-20200417.0428-2w (614)
2020-04-29.16:19:59 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200417.0428-2w
2020-04-29.16:19:59 [txg:869714] destroy tank/iocage/jails/plex@ioc_update_11.2-RELEASE-p6 (632)
2020-04-29.16:20:02 <iocage> zfs destroy tank/iocage/jails/plex@ioc_update_11.2-RELEASE-p6
2020-04-29.16:20:02 [txg:869716] destroy tank/iocage/jails/plex@ioc_plugin_update_2019-10-07 (645)
2020-04-29.16:20:04 <iocage> zfs destroy tank/iocage/jails/plex@ioc_plugin_update_2019-10-07
2020-04-29.16:20:04 [txg:869718] destroy tank/iocage/jails/plex@auto-20200421.0428-2w (682)
2020-04-29.16:20:06 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200421.0428-2w
2020-04-29.16:20:06 [txg:869720] destroy tank/iocage/jails/plex@auto-20200425.0428-2w (731)
2020-04-29.16:20:09 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200425.0428-2w
2020-04-29.16:20:09 [txg:869722] destroy tank/iocage/jails/plex@auto-20200429.0428-2w (777)
2020-04-29.16:20:11 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200429.0428-2w
2020-04-29.16:20:11 [txg:869724] destroy tank/iocage/jails/plex@auto-20200419.0428-2w (659)
2020-04-29.16:20:13 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200419.0428-2w
2020-04-29.16:20:13 [txg:869726] destroy tank/iocage/jails/plex@auto-20200423.0428-2w (710)
2020-04-29.16:20:15 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200423.0428-2w
2020-04-29.16:20:15 [txg:869728] destroy tank/iocage/jails/plex@auto-20200427.0428-2w (757)
2020-04-29.16:20:17 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200427.0428-2w
2020-04-29.16:20:17 [txg:869730] destroy tank/iocage/jails/plex@auto-20200422.0428-2w (700)
2020-04-29.16:20:20 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200422.0428-2w
2020-04-29.16:20:20 [txg:869732] destroy tank/iocage/jails/plex@auto-20200426.0428-2w (746)
2020-04-29.16:20:22 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200426.0428-2w
2020-04-29.16:20:22 [txg:869734] destroy tank/iocage/jails/plex@auto-20200418.0428-2w (646)
2020-04-29.16:20:24 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200418.0428-2w
2020-04-29.16:20:26 [txg:869738] destroy tank/iocage/jails/plex (363)
2020-04-29.16:20:28 <iocage> zfs destroy tank/iocage/jails/plex
2020-04-29.16:20:31 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200428.0428-2w
2020-04-29.16:20:33 <iocage> zfs destroy tank/iocage/jails/plex@auto-20200420.0428-2w
Yorick
Which might mean you have an underlying issue.
Hopefully not. Unless it's a 2-bit error. Anything in IPMI about that?
I think a lot of people don't use encryption, because of the added complexity and occasional instabillity.
pixel_punk
Do you have any pointers for me to investigate further?
Haven't done UI debugging yet...
From my understanding, deleting a jail from the UI should only do something like iocage clean && iocage destroy deleting the jail and associated datasets. I don't see how this could affect the whole pool in that way.
No. IPMI, Intel Memory Check on boot and also Memtest (ran for 2 days) show no RAM errors. The rest of the hardware is only a month old and did not show any errors during burn-in tests.
I wonder why. With GDPR and similar laws plus hardware encryption support, it's only a small take-away compared to the costs of secure hard drive disposal I think.
And geli or dm-crypt make the whole process quite convenient out of the box :)
Yorick
Sure, if this implementation was rock-solid. See the 11.3-U2 to 11.3U2.1 fiasco. My understanding is the OpenZFS 2.0 encryption methodology is more solid - time will tell.
