zpool import causes panic
I was running the FreeNAS 11 Nightly from 20180416. I came home and found the box had panic'd, so I reset and let the machine reboot. It panic'd again when it tried to import the main data set. It successfully imports the boot volume.
Things I have tried:
1. built new boot usb.
2. zpool import -f
3. zpool import -fF -o readonly
4. moved disks to another machine
zpool import command itself reports back that all 5 disks of the pool are online.
I am looking for suggestions. Thanks in advance.
It would be useful to see the exact panic output.
Also, hardware specs and the version of FreeNAS you were using before the nightlies. Also, why are you running the nightlies?
I have been running the nightlies for fun. No specific reason. I liked testing the new features.
FreeNAS version at crash - FreeNAS-11-MASTER-201804160410-78cda93
Hardware:
CPU- intel i5 2500-K (Socket LGA1155)
MB - Intel Desktop Board DZ77SL-50K
RAM - 32GB - 4 x 8GB
4 x 3TB disks+ 1 SSD for Zil
32GB SanDisk Ultra Fit (Boot)
Working on reducing the DB panic info pic size to post.
The final line is:
Stopped at kdb_enter+0x3b: movq $0,kdb_why
Screenshot from panic uploaded
  • screenshot001.pdf
I ran smartctl -a on each physical disk and all passed. The panic still happens on import.
Mehul V
  • Plug in the install USB, boot into it and then select "Shell"
  • Once in shell, can you run zpool import, zpool status and post the output here?
  • Do not try to import just yet or you will have to reboot and get back into shell everytime you need to run a command
zpool import
   pool: vd3
  state: ONLINE
 status: The pool was last accessed by another system.
 action: The pool can be imported using its name or numeric identifier and
		the '-f' flag.
   see: http://illumos.org/msg/ZFS-8000-EY
		vd3											 ONLINE
		  mirror-0									  ONLINE
			gptid/c31ed619-7891-11e4-afe7-002511e20540  ONLINE
			gptid/c43e301f-7891-11e4-afe7-002511e20540  ONLINE
		  mirror-1									  ONLINE
			gptid/f613211b-af2b-11e4-b0b6-002511e20540  ONLINE
			gptid/c5aa4fcb-7891-11e4-afe7-002511e20540  ONLINE
		logs
		  gptid/df7c20c6-e5c9-11e6-bcb1-e840f2d1ca87	ONLINE
zpool status
  pool: freenas-boot
 state: ONLINE
  scan: none requested
	   NAME		STATE	 READ WRITE CKSUM
	   freenas-boot  ONLINE	   0	 0	 0
		 da0p2	 ONLINE	   0	 0	 0
errors: No known data errors
It causes a kernel panic. See the initial posts for screen shots of the panic.
Same results occur with zpool import -f vd3 also.
Disks seem to be error free.
Mehul V
Here is what I did to stop kernel panic and actually try to recover:
DISCLAIMER: I would recommend taking pictures/screenshots at each and every steps listed here. If you dont understand something or you think you did something wrong, stop and post output/screenshot here instead of ignoring or trying the next step. We can't help if you missed one step and then wonder why it didn't work as intended.
  • Reboot FreeNAS and when GRUB loads up, press "E" to edit
  • Scroll down to where the single user mode section starts. You want to add following two lines. Make sure you scroll down to the right section and make sure to follow the format of existing lines.
set kFreeBSD.vfs.zfs.recover=1
set kFreeBSD.vfs.zfs.debug=1
After second line, press Enter and once you are on new line, press Tab and it should exit the edit mode.
  • Once you are done editing, you can press Ctrl + X and it will reboot the system.
Once the GRUB menu loads up again, be sure to select the single user mode that we edited previously.
Once it loads, you should get the following prompt:
"This will get you to the following screen, go ahead and press enter to start /bin/sh"
Type following command:
sh /etc/rc.initdiskless
Now you are ready to start trying to import your pools.
First pass is just trying a straight import:
# zpool import -R /mnt poolname
If it says recovery is possible but you might lose some data, take a look and see how much data has to be discarded:
If you get the recovery option but it complains that The pool was last accessed by another system and you have to use -f to force import, then try:
# zpool import -F -f poolname
If you get a panic then repeat the above steps, but try:
# zpool import -o readonly=on -R /mnt poolname
If this works your pool imported read only. Backup your data and life goes on.
As a final desperation move, or after you've managed to import the pool readonly and copy everything off you can try:
# zpool import -R /mnt -FX poolname
The above command has a good chance of destroying your pool, but it also has a chance of importing it.
Work Cited:
These steps were posted by @jpaetzel and @technopop on THIS thread. I just re-worded and re-arranged some of the things to make it easier to follow. It helped me with my issue so I figured it might help with yours.
I had the issue again. I was able to fix it, but modified the steps as 11.2 has a now version of GRUB.
I installed an 11.0 ISO to a different thumb drive and booted. I pressed E and ddded the ZFS parameters (
and press Ctrl-x to boot.
At the install menu and selected the Shell option.
Then I used the zpool import commands to import the volume, specifically the zpool import -F -f poolname.
This imported the volume. Then I rebooted using the original thumb drive and the volume has imported.
11.2 does not use GRUB. 11.2 uses the FreeBSD bootloader, which has gained support for all necessary features since 9.3.
any suggestion how to do a similar process after upgrading the zpool, i.e. I can't do the previous process as the disks can't be imported as read/write.
with 11.3, I pressed space to stop the boot and selected the loader options. At the OK prompt I typed:
set vfs.zfs.recover=1
set vfs.zfs.debug=1
boot
The booted the vanilla system and then I was able to run zpool import -f -F <volumename> to import the volume.
