polakkenak
- Jun 10, 2022
Hi folks. I'm fairly new to TrueNAS and ZFS, so please bear with me.
I recently bought a minisforum HM90 to serve serve my need for running VMs at home.
I put in 2x8GB of new memory and two older sata SSDs I had laying around.
After running for a short while, SCALE warns me that one of the pools are in a degraded state. This happens on a fresh install of SCALE 22.02.1
After clearing the pool status and running a new scrub, the error will appear almost immediately again.
Doing some testing, I found that the problem would appear on whichever disk was plugged into the "JFPC1" port, while the drive attached to the other port had no problem.
I thought this problem was caused by a hardware problem (e.g. faulty sata port/controller) and contacted the reseller to enquire about repairs and the reseller said this could be a compatibility problem and I should try to replicate the problem on windows before sending it in for repairs.
I tried this, and I wasn't able to cause windows to complain about the drive during the testing I did. Windows doesn't really offer zfs support, so take this statement with a grain of salt.
I have tried replicating the problem again with a live usb for both proxmox and ubuntu server, and neither of these detected any problem. Running TrueNAS in recovery mode (off the boot drive, not USB) also does not show any problems with the drive.
So, to summarize:
I'm stumped as to what is causing this problem. Could a setting be causing this problem?
root@truenas[~]# zpool status boot-pool
pool: boot-pool
state: DEGRADED
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: scrub repaired 0B in 00:00:13 with 0 errors on Fri Jun 10 07:59:52 2022
NAME STATE READ WRITE CKSUM
boot-pool DEGRADED 0 0 0
sdb3 DEGRADED 23 0 34 too many errors
errors: No known data errors
root@truenas[~]# zpool clear boot-pool
root@truenas[~]# zpool scrub boot-pool
pool: boot-pool
state: DEGRADED
scan: scrub repaired 0B in 00:00:13 with 0 errors on Fri Jun 10 08:42:57 2022
sdb3 DEGRADED 16 0 79 too many errors
So, to summarize:
- zpool status says a pool is degraded
- Changing "sata" port move the problem to the other drive
- Testing while running off a live USB doesn't exhibit the same problem
- Testing while in truenas recovery mode doesn't exhibit the same problem
