ZFS Status Unknown
JIsabelle218
Greetings,
I just upgraded from: 8.0.4 Release P3 - amd 64 - 06-13-12 to: FreeNAS-8.3.0-RC1-x64 (r12617).
Did a GUI update and everything works fine, but I am getting a flashing alert light in the top right corner of the web interface with the following:
"WARNING: The volume Volume1 (ZFS) status is UNKNOWN: The pool is formatted using an older on-disk format. The pool can still be used, but some features are unavailable.Upgrade the pool using 'zpool upgrade'. Once this is done, the pool will no longer be accessible on older software versions."
Not really sure what this means or how to fix.
Any help would be appreciated
Thank you
BobCochran
