ZFS snafoo help please!!
Ryan Hunter
So I've had multiple disk failures in my mirrored zpool. I went to replace a failed disk, and for stupid reasons that I'm kicking myself for I did a replace disk on the good disk not the failing one on accident. I also did not offline the good disk before removing it. My question is can I add that back to the pool as a disk of that mirror set or am I completely screwed? If I can't do this I have file corruption and will have to start from scratch. I have a currently good unplugged disk ready to go for that mirror set if there's some way I can reactivate it. I also have another disk failing in a different mirror set in the pool but I havent addressed that yet. Any help would be appreciated.
Thanks,
Ryan
SweetAndLow
Sweet'NASty
Read rules...
1. freenas version
2. zpool status output
Ryan Hunter
My apologies, thanks for the reminder.
1. version: 9.3-STABLE-201509160044
2. zpool status output:
pool: Main
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 36.8M in 9h33m with 3937 errors on Sun Sep 27 00:44:38 2015
NAME STATE READ WRITE CKSUM
Main DEGRADED 0 0 320K
mirror-0 ONLINE 0 0 0
ada0 ONLINE 0 0 0
ada2 ONLINE 0 0 0
mirror-1 DEGRADED 0 0 641K
18227011415578332557 UNAVAIL 0 0 0 was /dev/gptid/6c9d931f-6400-11e5-9788-e03f49b5ed41
gptid/e5ad17c8-5f7a-11e2-8d0c-1c6f65b32ba1 DEGRADED 0 0 641K too many errors
mirror-2 DEGRADED 0 0 0
gptid/4a2182c2-8b0f-11e4-8b9c-e03f49b5ed41 ONLINE 0 0 0
7528400846399397006 REMOVED 0 0 0 was /dev/gptid/4a7d2217-8b0f-11e4-8b9c-e03f49b5ed41
I would reboot the machine. The "good" drive will go back into the system if you haven't 'detached' the drive from the zpool.
If you did, you should just destroy the zpool and restore from backup.
