Hello all
I have currently set up a raid mirror UFS with two disks, respectively, 250 and 500 gb using FreeNAS 9.1.1.
I need to figure out how to sync / match data between two disks in case I change or add data only in one and the other is unplugged.
I did a test by unplugging a disk and adding a file in the other connected, but once I plugged in the second disk i couldn't see that file.
In a few words so I was wondering if there is a mechanism for automatic synchronization/parity just in case you are working on only one disk at the moment and in a second time adding the second one of RAID mirror set up.
Thanks in advance.
Thanks in advance.
