ZFS setup with
cmonty14
I'm new to TrueNAS and OpenZFS.
Before I continue with my ZFS setup I would like to clarify if my understanding is correct.
So, is it correct that a ZFS pool that consists of multiple vdevs, any vdev must be equal in
  • number of disks included in each vdev
  • RAID level
In case I have drives of different sizes (4TB, 2TB, 1TB), is it correct that a vdev should enclude only drives of the same size?
And what about partitions?
Would it make sense to include partitions (of the same size) of different drives in the same vdev?
THX for your replies.
  • RAID level
If you replace must with should in that statement, then you're right.
We would recommend that you do it like that, but for example, you may have a pool of 2 RAIDZ2 VDEVs where you also have a 3-way mirror of SSDs for a special/metadata VDEV.
Depending on your performance objectives, it may also make perfect sense to have RAIDZ2 VDEVs of differing sizes in the same pool... although with a pool for high IO, you wouldn't usually want to mix the site of any of the Mirrored VDEVs in the pool.
Yes, correct, should.
Any differently sized drives in the same VDEV will have their "excess capacity" (judged in comparison to the smallest drive in the VDEV) ignored anyway.
If you want to be supported in what you're doing, you assign entire disks.
Custom (and unsupported) work with the CLI can be done to have partitions participating in a pool... for folks who know what they are doing and are prepared to deal with the consequences of what they do.
As already said, that's automatic (ignoring the excess)... and not recommended. But can make sense on your way to increasing all disks in the pool to the same size (which will automatically expand the pool to full size when the last disk reaches the full final size).
