So I have read of a few people losing data because of not meeting the minimum amount of RAM (8 gigs). I full well plan to start the build with 16 gigs of RAM, and yes, FOR SURE ECC...
My question is, I may end up going with 9x4 TB thus 28 TB of usable space, 36 TB of full hhd space. Is there any data risk to running "only" 16 gigs of RAM. I am assuming because my workload is very low, performance should be ok. But assuming performance is at least acceptable (in which case I may upgrade ram latter), there is at least no data integrity issue with this correct? As long as you are not grossly under the 1TB-1GB rule, there isn't any data loss issue correct? Or is there only data integrity issue if you are under 8 gigs of RAM?
I guess a better way to phrase this, if you run less than 8 gigs of RAM you can run into data integrity issues, but could you run a VERY large ZFS pool (say 50+TB) with say 16 gigs of ram, have crappy performance, but not have data integrity issues?
