zfs send and receive does not finish
nas4free-user
I try to move datasets from XigmaNAS to Freenas by:
zfs send pool/dataset@snapshot | ssh destination-IP zfs receive -F dpool/dataset1/received-dataset
everything is fin for small datasets (100GB), but when trying with > 1TB, anytime (after > 100 GB) I get a
"connection closed by remite host" error all transfered data are being deleted.
How can I monitoring whats going on on FreeNAS?
Can I log anything during thr transmission?
Regards,
Frank
How short is your snapshot interval?
could it be the case that the daily snapshot runs while the larger transfer is still running?
melloa
Test with rsync --av --progress <source> <destination>, to see if you can transfer the files.
nas4free-user
Actually, I shifted from rsync to sednd & receive snapshots for performance reasons!
I'm going to disable automatic snapshots and try again!
nas4free-user
Problem solved!
After I disabled the automatic snapshot for the dataset to be transferred, everything went fine!
Probably, it must not be taken a newer snapshot while transferring an existing snapshot!?
Regards,
Frank
