I've temporally re-installed the drive and resilvered the zpool. I also re-scrub it and it still online.
The output if the smartctl -a command is the following:
[root@nas] ~# smartctl -a /dev/da4
smartctl 5.41 2011-06-09 r3365 [FreeBSD 8.2-RELEASE-p6 amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen,
http://smartmontools.sourceforge.net
Model Family:     Western Digital Caviar Green (Adv. Format)
Device Model:     WDC WD20EARS-07MVWB0
Serial Number:    WD-WCAZA7968059
LU WWN Device Id: 5 0014ee 205f360c9
Firmware Version: 51.0AB51
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
ATA Version is:   8
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Sun Mar  4 09:46:48 2012 GMT
SMART support is: Enabled
SMART STATUS RETURN: incomplete response, ATA output registers missing
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (38460) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 255) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   195   194   051    Pre-fail  Always       -       1299
  3 Spin_Up_Time            0x0027   253   253   021    Pre-fail  Always       -       1025
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       112
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   096   096   000    Old_age   Always       -       3315
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       110
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       108
193 Load_Cycle_Count        0x0032   198   198   000    Old_age   Always       -       8848
194 Temperature_Celsius     0x0022   124   107   000    Old_age   Always       -       26
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       1
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
