zfs reporting degraded drive ..
experiencing issues with zfs.. Trying to correct this error.. Need some assistance
undaunted-pc tank # zpool status
pool: tank
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Sat Feb 15 05:00:08 2020
6.96M scanned out of 1.32T at 178K/s, (scan is slow, no estimated time)
36K resilvered, 0.00% done
NAME STATE READ WRITE CKSUM
tank DEGRADED 0 0 0
raidz1-0 ONLINE 0 0 0
sde ONLINE 0 0 0
sdb ONLINE 20 133 2 (resilvering)
sdc ONLINE 0 0 0
raidz1-1 DEGRADED 0 0 0
sdd ONLINE 0 0 0
219805507191516579 UNAVAIL 0 0 0 was /dev/sdf1
sdh ONLINE 0 0 0
Hi @Norman Hawkins. Are you using FreeNAS? If so, have you been doing pool maintenance from the CLI? I ask because I notice the drive labels are sdX rather then the normal UUID you'd expect from the FreeNAS GUI. If you're using FreeNAS you want to try to use the GUI, failing to do so can result in the system being misconfigured and unable to fully manage your pool.
To answer your immediate question, it looks like you may have two bad disks. Did you start any resilvering yet? It looks like the system thinks sdb is resilvering and that sdf needs to be replaced as well?
