ZFS replication woes
aufalien
I've a 9.1.1 box (PUSH) that I would like to replicate to a fresh 9.2.1.5 box (PULL).
My volume is foo and the dataset of BAR.
Both boxes have foo/BAR defined.
On PUSH, I have a snap shot of foo/BAR, no snapshots on PULL.
Under replication tasks;
Filesystem/Volume = foo/BAR
Remote ZFS filesystems name = foo/BAR
Initialize remote side for once is enabled
Remote host has an IP address which is valid and reachable.
I have chosen to not use a dedicated user.
I dropped into the command and followed troubleshooting on page 108-109 of the manual.
The ssh test works fine, no password is asked so my preshared key works;
ssh -vv -i /data/ssh/replication 10.0.10.99
Also doing the next test;
zfs send foo/BAR@auto-20140423.2245-2h | ssh -i /data/ssh/replication 10.0.10.99 zfs receive foo/BAR@auto-20140423.2245-2h
Yields this error;
Could not create directory '/root/.ssh'.
cannot receive new filesystem stream: destination 'foo/BAR' exists
must specify -F to overwrite it
warning: cannot send 'foo/BAR@auto-20140423.2245-2h': Broken pipe
I assume this is fine as the option "initialize remote side for once" is doing the -F.
However using the GUI, I cannot get this process to launch.
What am I doing wrong?
aufalien
UPDATE; I had to choose both recursive and initiate. Not super crazy on initiate and hope that I don't have to do that each and every time a rep is needed. I'm hoping this is the case since its an initial rep task and that no further initiates will be needed.
aufalien
Curious, its been bothering me. Why is it that I cannot replicate an individual dataset? I can rep the entire volume with that dataset, just not the dataset.
I would enjoy the granularity in being able to do this. Has any one been able to rep just a dataset and if so, can you share your settings with me?
If your snapshot covers a dataset, then the replication will be for just that dataset.
If your snapshot covers the pool, then your replication will be for the pool.
This is one of those "why would I want a dataset over a folder" moments.
aufalien
I redid my snapshot specifying foo/BAR as per my example.
However under replication, I chose both recursive and initialize options.
Its helps to have some one confirm so thanks for that.
aufalien
Curious, seeing that concurrent replication is currently not possible (https://bugs.freenas.org/issues/4523), what would you suggest in terms snapshot methodology?
Is it more reliable to snapshot an entire volume or individual datasets off that volume?
