Thanks for the reply
camcontrol devlist:
<QEMU QEMU DVD-ROM 2.5+> at scbus1 target 0 lun 0 (cd0,pass0)
<QEMU QEMU HARDDISK 2.5+> at scbus2 target 0 lun 0 (pass1,da0)
<QEMU HARDDISK 2.5+> at scbus3 target 0 lun 0 (ada0,pass2)
<QEMU HARDDISK 2.5+> at scbus4 target 0 lun 0 (ada1,pass3)
On the host system related drives are:
/dev/sdb1: TYPE="zfs_member" PARTUUID="a38bdf36-c305-11e6-bd9d-ef7f8e4689ee"
/dev/sdb2: TYPE="zfs_member" PARTUUID="a39a717e-c305-11e6-bd9d-ef7f8e4689ee"
/dev/sdc1: PARTUUID="3d06c5e9-c929-11e6-9bf3-01af3f2ae076"
/dev/sdc2: PARTUUID="3d23b89d-c929-11e6-9bf3-01af3f2ae076"
gpart show ...
=> 34 15628053101 ada0 GPT (7.3T)
34 94 - free - (47K)
128 4194304 1 freebsd-swap (2.0G)
4194432 15623858696 2 freebsd-zfs (7.3T)
15628053128 7 - free - (3.5K)
=> 40 15628053088 ada1 GPT (7.3T)
40 4056 - free - (2.0M)
4096 4194304 1 freebsd-swap (2.0G)
4198400 15623852032 2 freebsd-zfs (7.3T)
15628050432 2696 - free - (1.3M)
zpool status (affected pool not imported because cannot be found):
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:07 with 0 errors on Fri Dec 15 03:45:07 2017
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
zpool import
pool: main
state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
devices and try again.
see:
http://illumos.org/msg/ZFS-8000-3C
main UNAVAIL insufficient replicas
mirror-0 UNAVAIL insufficient replicas
17629389395766204468 UNAVAIL cannot open
11293553033617356016 UNAVAIL cannot open
I hope this helps - again FreeNAS is running as a VM - below therefore also the config file for qemu:
bios: ovmf
bootdisk: scsi0
cores: 4
ide2: none,media=cdrom
memory: 18432
net0: e1000=XX:XX:XX,bridge=vmbr0
numa: 0
onboot: 1
ostype: other
sata0: /dev/disk/by-path/pci-0000:01:00.0-sas-phy4-lun-0
sata1: /dev/disk/by-path/pci-0000:01:00.0-sas-phy5-lun-0
scsi0: local-zfs:vm-100-disk-1,size=20G
scsihw: virtio-scsi-pci
smbios1: uuid=88332963-5f6e-XXXX-XXXX-XXXXX
sockets: 1
Regards
