ZFS Pool Failure
Xylex
I have been using ZFS for quite some time now. I understand the simple zpool commands and how to scrub and manually mount/import a pool.
This post is about my 2nd NAS I have built.
Hardware Specs:
Board: Supermicro X7DWU
BIOS: 7DWUB048
RAM: x8 CT51272AF667 - 4GB FBDDR2 667 = 32GB (Yes, 32GBs of Fully Buffered RAM)
ada0: WD2500JD-00HBB0 250GB Sata - BOOT DRIVE
ada1-3: ST31000524A2
ada4: WD10EALX
I am going to start from the beginning.
I have an ESX server that hosts many environments.
A few of them operate from this NAS.
I was recently having memory errors on my ESX server, so I pulled it and the NAS, as the NAS was on top of the ESX server.
I performed my memory tests, and replaced the bad DIMMS, and promptly re-racked both servers. I made NO CHANGES to the NAS.
Upon powering the NAS up, If find that my zfs pool "zfs" couldn't remount.
This is what I get when I try to manually remount it:
   pool: zfs
  state: UNAVAIL
 status: One or more devices are missing from the system.
 action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: http://www.sun.com/msg/ZFS-8000-3C
        zfs                      UNAVAIL  insufficient replicas
          raidz1-0               UNAVAIL  insufficient replicas
            3991037278626503309  UNAVAIL  cannot open
            ada4                 ONLINE
            69528833404146203    UNAVAIL  cannot open
            ada3                 ONLINE
Side note: This is the first time I have gotten ada3 and ada4 to both come online. This is simple just trial and error of moving drives around.
Strangely the drives I am having issues with are only the Seagates. (Until now of course)
I cannot loose this data, any sugestions?
Well, from experience with someone else that had bad RAM on your FreeNAS server you have roughly 100% chance of no recovery.
Can you provide more info on your ESX VM? How much RAM did it have. What method did you use to make the drives available to the VM?
Do NOT do ANYTHING with those drives until you hear from one of the senior guys that says you are screwed. There's been a few people that thought they new better and started doing stuff they thought was safe and actually lost their data because they didn't listen to this tip. Let me say this again... DO NOT CHANGE ANYTHING ON YOUR VM, HARDWARE, ETC UNTIL A SENIOR POSTER SAYS TO.
William Grzybowski
I don't believe bad RAM would cause any of this.
ZFS simply cannot find any disks with the zfs labels on them. Are you sure the drive order have not changed somehow and the wrong disks are attached to the FreeNAS VM?
Another thing I noticed, you have full disks with ZFS, which is not the recommended way, did you manually create that pool?
Paste:
# gpart show
# glabel status
# sysctl kern.disks
Xylex
Forgive me, think I need to clarify.
I had Bad RAM on the ESX box, NOT the NAS. The specs I posted are the NAS.
To answer William's question.
I made the Volume in the WebUI Volume manager, then made shares and started storing data.
Also, I came back in this morning to find that ada2-4 are marked unavailable, and ada1 is online.
[root@freenas] ~# gpart show
=>       63  488397105  ada0  MBR  (232G)
         63    1930257     1  freebsd  [active]  (942M)
    1930320         63        - free -  (31k)
    1930383    1930257     2  freebsd  (942M)
    3860640       3024     3  freebsd  (1.5M)
    3863664      41328     4  freebsd  (20M)
    3904992  484492176        - free -  (231G)
=>        34  1953525101  ada2  GPT  (931G) [CORRUPT]
          34          94        - free -  (47k)
         128     4194304     1  freebsd-swap  (2.0G)
     4194432  1949330703     2  freebsd-zfs  (929G)
=>      0  1930257  ada0s1  BSD  (942M)
        0       16          - free -  (8.0k)
       16  1930241       1  !0  (942M)
=>        34  1953525101  ada3  GPT  (931G) [CORRUPT]
=>        34  1953525101  ada4  GPT  (931G) [CORRUPT]
glable status
[root@freenas] ~# glabel status
                                      Name  Status  Components
                             ufs/FreeNASs3     N/A  ada0s3
                             ufs/FreeNASs4     N/A  ada0s4
gptid/0df5e718-5a11-11e2-9a01-0025902238e8     N/A  ada2p2
                            ufs/FreeNASs1a     N/A  ada0s1a
gptid/0d45ad62-5a11-11e2-9a01-0025902238e8     N/A  ada3p2
gptid/0da39302-5a11-11e2-9a01-0025902238e8     N/A  ada4p2
sysctl kern.disks
[root@freenas] ~# sysctl kern.disks
kern.disks: ada4 ada3 ada2 ada1 ada0
Xylex
Paste:
# gpart show
# glabel status
# sysctl kern.disks
I have posted the command outputs for you.
Just out of an idea, can you post the model number and firmware version listed on the label of your Seagate drives.
Right now I'm kind of thinking this may be a situation where you didn't do anything to the server, but you technically did. You moved it when you pulled it, and there may have been some loose connection that has severed since it has moved. Also, from extensive experience with electronics I can tell you that the most common time stuff breaks is when you turn it off and turn it on. Of course, generally if it breaks when it shuts off you won't know until you turn it on and it doesn't work. It's possible that you have drives that are intermittently failing and now that you've turned them off and on you're finding out they're not in the best of condition.
As another option, you could take the FreeNAS installation disk and 4 disks and try them in another machine. As long as the SATA controller is compatible FreeNAS should just boot right up after you chose the USB stick as the boot device. Generally onboard Intel controllers work perfectly. Since you only have 4 drives most motherboards have at least 4 ports on an Intel controller.
Big picture, there's really not alot of information to go on and it sounds like it will simply take some plain old troubleshooting by you to determine the actual problem. Just be careful what commands you start running from the CLI. You definitely don't want to inadvertently do something that writes anything to the drives. I think that if you play around and experiment you'll figure out what is wrong and be able to get to your data. Depending on the failure mode you may want to consider pricing out new drives in the very near future.
Xylex
To be honest with you, I already have done this.
The drives that are failing are my 3 Seagates. They started doing this at the same time, the drives them selves pass SMART, they pass 2 different's stress tests. The drives themselves are fine.
I already put the drives in a completely different machine to get the same issue.
I dont post on forums unless I feel that I have done everything I could.
paleoN
What's the rest of the story? FreeNAS 8 GUI doesn't use whole disks or did you manually type that first post?
Did ada1 ever have any partitions on it?
What machine were they in when you ran the commands above?
Save your current config, restore factory defaults (or install latest release to a new usb stick), do not restore the config and rerun the following:
zpool import
camcontrol devlist
glabel status
gpart show
Xylex
The drivers were blank when I made the volume, and I did it all in the GUI.
This is FreeNAS 8.3 and I simple created the volume, then created shares.
I can get you an output Monday, as the server at my Datacenter.
Xylex
No, it did not.
The Specs listed above. The Original server.
zpool import
camcontrol devlist
glabel status
gpart show
Alright. This is CLEAN Install of FreeNAS 8.3 x64 On the server (Specs in my first post.) Installed on ada0, Which is the 250GB WDC Drive listed in my output:
zpool import
[root@freenas] ~# zpool import
   pool: zfs
  state: UNAVAIL
            14980719057705672504  UNAVAIL  cannot open
            ada1                  ONLINE
camcontrol devlist
[root@freenas] ~# camcontrol devlist
<WDC WD2500JD-00HBB0 08.02D08>     at scbus0 target 0 lun 0 (pass0,ada0)
<WDC WD10EALX-009BA0 15.01H15>     at scbus1 target 0 lun 0 (pass1,ada1)
<ST31000524AS JC4B>                at scbus2 target 0 lun 0 (pass2,ada2)
<ST31000524AS JC4B>                at scbus3 target 0 lun 0 (pass3,ada3)
<ST31000524AS JC4B>                at scbus4 target 0 lun 0 (pass4,ada4)
glabel status
gpart show
Let me know if you need me to run any other commands.
paleoN
No, It did not.
Then you didn't create this pool via FreeNAS 8.3 GUI unless you think you found some obscure bug.
gpart list ada4
zdb -l /dev/ada1
zdb -l /dev/ada3
zdb -l /dev/ada3p2
Sorry for the double post. Page broke for me and made me think it didnt post.
Just delete the double post.
Xylex
1) All the drivers were blank from the start
2) I CREATED the zfs RAIDZ1 Pool In the FreeNAS 8.3 GUI
3) I Created the shares and started to store data on them.
gpart list ada4
zdb -l /dev/ada1
zdb -l /dev/ada3
zdb -l /dev/ada3p2
gpart list ada4
[root@freenas] ~# gpart list ada4
Geom name: ada4
modified: false
state: CORRUPT
fwheads: 16
fwsectors: 63
last: 1953525134
first: 34
entries: 128
scheme: GPT
Providers:
1. Name: ada4p1
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e0
   rawuuid: 0d912e13-5a11-11e2-9a01-0025902238e8
   rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 2147483648
   offset: 65536
   type: freebsd-swap
   index: 1
   end: 4194431
   start: 128
2. Name: ada4p2
   Mediasize: 998057319936 (929G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 2147549184
   Mode: r0w0e0
   rawuuid: 0da39302-5a11-11e2-9a01-0025902238e8
   rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b
   label: (null)
   length: 998057319936
   offset: 2147549184
   type: freebsd-zfs
   index: 2
   end: 1953525134
   start: 4194432
Consumers:
1. Name: ada4
   Mediasize: 1000204886016 (931G)
   Sectorsize: 512
   Mode: r1w1e1
zdb -l /dev/ada1
[root@freenas] ~# zdb -l /dev/ada1
LABEL 0
    version: 28
    state: 0
    txg: 190705
    pool_guid: 331113494358268866
    hostid: 3549322712
    hostname: 'freenas.local'
    top_guid: 16107481134572789769
    guid: 9766453488593238848
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        asize: 4000799784960
        is_log: 0
        children[0]:
            type: 'disk'
            guid: 3991037278626503309
            path: '/dev/ada3'
            phys_path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            guid: 14980719057705672504
            path: '/dev/ada0'
            phys_path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            guid: 69528833404146203
            path: '/dev/ada2'
            phys_path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            phys_path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
LABEL 1
    version: 28
    state: 0
    txg: 190705
    hostid: 3549322712
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
LABEL 2
    version: 28
    state: 0
    txg: 190705
    hostid: 3549322712
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
LABEL 3
    version: 28
    state: 0
    txg: 190705
    hostid: 3549322712
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
zdb -l /dev/ada3
[root@freenas] ~# zdb -l /dev/ada3
LABEL 0
    version: 28
    state: 0
    txg: 190705
    hostid: 3549322712
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
LABEL 1
    version: 28
    state: 0
    txg: 190705
    hostid: 3549322712
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
LABEL 2
    version: 28
    state: 0
    txg: 190705
    hostid: 3549322712
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
LABEL 3
    version: 28
    state: 0
    txg: 190705
    hostid: 3549322712
    vdev_children: 1
    vdev_tree:
        type: 'raidz'
        nparity: 1
        metaslab_array: 23
        metaslab_shift: 35
        ashift: 9
        is_log: 0
        children[0]:
            type: 'disk'
            path: '/dev/ada3'
            whole_disk: 0
            DTL: 37
        children[1]:
            type: 'disk'
            path: '/dev/ada0'
            whole_disk: 0
            DTL: 36
        children[2]:
            type: 'disk'
            path: '/dev/ada2'
            whole_disk: 0
            DTL: 35
        children[3]:
            type: 'disk'
            path: '/dev/ada1'
            whole_disk: 0
            DTL: 34
zdb -l /dev/ada3p2
[root@freenas] ~# zdb -l /dev/ada3p2
LABEL 0
failed to unpack label 0
LABEL 1
failed to unpack label 1
LABEL 2
failed to unpack label 2
LABEL 3
failed to unpack label 3
paleoN
Before you shutdown output of:
swapctl -ls
Congrats on the bug then.
According to at least two of your drives ZFS was always using the whole disks and not the partitions. After running the above command shutdown and reorder the disks how they last successfully appeared in the pool, which is something like:
Keep ada1 where it is.
Swap ada3 & ada2.
Swap ada4 & ada0.
Then boot up mfsBSD or the latest live FreeBSD BETA.
zpool import
zdb -l /dev/ada0
zdb -l /dev/ada0p2
zdb -l /dev/ada2
zdb -l /dev/ada2p2
zdb -l /dev/ada3
zdb -l /dev/ada3p2
Xylex
I am jumping the gun with my response.
I did zpool import on a mfsBSD live CD and found that the pool was healthy.
My stomach churned when I found I was able to browse my pool.
I am currently copying everything off of the pool.
Is there any more information I can post that can and will help identify and resolve this potential bug?
What is it exactly is happening that shouldn't be? It seems to relate to the manner I created the volume?
paleoN
I suppose I'll jump the gun with mine then. :eek:
Excellent. :D Given that one of the other drives showed online earlier, hope should certainly have been alive.
+1 Would have suggested this very thing.
I have been doubtful that there was a bug. The exact FreeNAS version, build, etc and the steps you took to create the pool in excruciating detail. Then successfully reproduce the problem.
I don't suppose your ran beforehand:
swapctl -ls
Moving all the drives around should be completely unnecessary. FreeBSD should simply taste the disks again and find who's where. Furthermore, the 2 sets of labels you posted appeared intact. My suspicion is FreeNAS enabled swap on the 3 partitioned drives, which held the partition open and which screwed up ZFS from being able to properly open the drives itself.
