zfs pool degradation but HD appears OK?
Blasm12
Several days ago, noticed my freenas data was degradated.
So, after running:
zpool status (" gptid/8d59bd77-cbf2-11e4-afcf-0cc47a004dac DEGRADED"), then
glabel status ("gptid/8d59bd77-cbf2-11e4-afcf-0cc47a004dac N/A ada3p2"), then smartcl (below).... It appears to me the drive is ok, but the data cannot be resilverd to bring the drive back in sync?
I ran the extended SMART test on the drive this morning.
the steps illustrated (ID drive, SMART printout) in text document attached.
Appreciate any help.
I believe the drive was disconnected for several days (bad hot swap bay power)... and is unable to recover?
Thanks again
  • degradation.txt
Robert Trevellyan
Pony Wrangler
It's possible for a drive to go bad without any SMART failures. However, if it was just a case of the drive losing power, you could follow the directions in the documentation for replacing a failed drive, but instead of installing a new drive, wipe the one you have and then reuse it. You might even be able to do an in-place replacement without wiping it. Your pool is safe for now because you were smart enough to go with a RAIDZ2 vdev layout.
Blasm12
Can I simply "wipe" the drive from the FreeNAS GUI (view disks screen)? Then it will repopulate the drive?
-OR-
I have an extra (same model HD/size) drive... Can I shut down the system.. replace drive.. reboot, then it will repopulate?
Thanks Again
Blasm12
heres code posted again
login as: root
root@192.168.1.95's password:
Last login: Sat Jul 11 09:48:15 2015 from 192.168.1.90
FreeBSD 9.3-RELEASE-p10 (FREENAS.amd64) #0 r275790+4663c83: Sat Mar  7 08:41:07        PST 2015
        FreeNAS (c) 2009-2015, The FreeNAS Development Team
        All rights reserved.
        FreeNAS is released under the modified BSD license.
        For more information, documentation, help or support, go here:
        http://freenas.org
Welcome to FreeNAS
[root@freenas] ~# zpool status
  pool: NASVOL1
state: DEGRADED
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
   see: http://illumos.org/msg/ZFS-8000-9P
  scan: scrub repaired 127G in 16h20m with 0 errors on Thu Jul  9 14:47:22 2015
        NAME                                            STATE     READ WRITE CKS        UM
        NASVOL1                                         DEGRADED     0     0        0
          raidz2-0                                      DEGRADED     0     0        0
            gptid/8c4970e5-cbf2-11e4-afcf-0cc47a004dac  ONLINE       0     0        0
            gptid/8ca23563-cbf2-11e4-afcf-0cc47a004dac  ONLINE       0     0        0
            gptid/8cfdcbf5-cbf2-11e4-afcf-0cc47a004dac  ONLINE       0     0        0
            gptid/8d59bd77-cbf2-11e4-afcf-0cc47a004dac  DEGRADED     0     0 4.1        8M  too many errors
            gptid/8daadbe3-cbf2-11e4-afcf-0cc47a004dac  ONLINE       0     0        0
            gptid/8e061899-cbf2-11e4-afcf-0cc47a004dac  ONLINE       0     0        0
errors: No known data errors
  pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Sat Jul 11 03:46:02 2015
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
[root@freenas] ~# glabel status
                                      Name  Status  Components
gptid/72b176b8-c614-11e4-8d1e-0cc47a004dac     N/A  da0p1
gptid/8c4970e5-cbf2-11e4-afcf-0cc47a004dac     N/A  ada0p2
gptid/8ca23563-cbf2-11e4-afcf-0cc47a004dac     N/A  ada1p2
gptid/8cfdcbf5-cbf2-11e4-afcf-0cc47a004dac     N/A  ada2p2
gptid/8daadbe3-cbf2-11e4-afcf-0cc47a004dac     N/A  ada4p2
gptid/8e061899-cbf2-11e4-afcf-0cc47a004dac     N/A  ada5p2
[root@freenas] ~# smartcl -a/dev/ada3
[root@freenas] ~# smartctl -a /dev/ada3
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p10 amd64] (local build)
Model Family:     Seagate NAS HDD
Device Model:     ST4000VN000-1H4168
Serial Number:    Z302C7VH
LU WWN Device Id: 5 000c50 0794776ee
Firmware Version: SC44
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5900 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sat Jul 11 09:55:01 2015 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  107) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 518) minutes.
Conveyance self-test routine
SCT capabilities:              (0x10bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   119   099   006    Pre-fail  Always       -       229554504
  3 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       21
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   070   060   030    Pre-fail  Always       -       12416117
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       1283
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       21
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   069   066   045    Old_age   Always       -       31 (Min/Max 24/34)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       14
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       21
194 Temperature_Celsius     0x0022   031   040   000    Old_age   Always       -       31 (0 20 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%      1281         -
# 2  Extended offline    Completed without error       00%      1248         -
# 3  Short offline       Interrupted (host reset)      00%      1128         -
# 4  Short offline       Completed without error       00%      1127         -
# 5  Short offline       Completed without error       00%      1126         -
# 6  Short offline       Completed without error       00%      1125         -
# 7  Short offline       Completed without error       00%      1124         -
# 8  Short offline       Completed without error       00%      1123         -
# 9  Short offline       Completed without error       00%      1122         -
#10  Short offline       Completed without error       00%      1121         -
#11  Short offline       Completed without error       00%      1120         -
#12  Short offline       Completed without error       00%      1119         -
#13  Short offline       Completed without error       00%      1118         -
#14  Short offline       Completed without error       00%      1117         -
#15  Short offline       Completed without error       00%      1116         -
#16  Short offline       Completed without error       00%      1115         -
#17  Short offline       Completed without error       00%      1114         -
#18  Short offline       Completed without error       00%      1113         -
#19  Short offline       Completed without error       00%      1112         -
#20  Short offline       Completed without error       00%      1111         -
#21  Short offline       Completed without error       00%      1110         -
[root@freenas] ~#
to avoid opening txt file.
Robert Trevellyan
Pony Wrangler
-OR-
The first option would probably work. I like the 2nd option, because you can then take your time running other tests on the replaced drive, and put it away as a spare if it seems OK.
By the way, hourly short SMART tests seems like overkill to me. Daily is more than sufficient in my opinion.
Blasm12
thank-you.
decided to replace the drive with machine off.
After reboot, CLI "zpool status" shows new drive (below), but GUI wont give me "replace" tab when I view "storage>volume>view disks"....
GUI shows ada3 with new serial number.
I guess I'm not sure how to get it back in the pool if GUI doesnt give me "replace" tab?
(and thanks for the SMART test advice!)
login as: root
Last login: Sun Jul 12 07:14:34 2015 from 192.168.1.90
        http://freenas.org
Welcome to FreeNAS
  pool: NASVOL1
state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
        the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: scrub repaired 0 in 13h5m with 0 errors on Sun Jul 12 02:53:47 2015
            16193153246620218562                        UNAVAIL      0     0     0  was                                                          /dev/gptid/8d59bd77-cbf2-11e4-afcf-0cc47a004dac
  pool: freenas-boot
state: ONLINE
          da0p2     ONLINE       0     0     0
[root@freenas] ~#
Robert Trevellyan
Pony Wrangler
There is a documented procedure for replacing a drive. Step 1 is to offline the 'bad' drive, which I'm guessing you didn't do. I expect you can recover by temporarily installing the old drive and then offlining it, but there's probably an easier way too. Maybe you can just offline the disk FreeNAS sees now, then do an in-place replacement.
Blasm12
Yes, section 8.1.10 ( in 9.3 documentation: http://doc.freenas.org/9.3/freenas_storage.html). I've read it numerous times.
The problem was/is .. There was no tab to to take the degraded disk "offline" (in disk view screen at bottom) ... Which according to the documentation means it was already off line.
Then I powered off, replaced the drive w a new similar drive, reboot..... And Voila!.... The GUI ("disk view") shows the drive as part of the volume, new HD serial number for new drive visible, (highlighting the drive... Shows 2 tabs at bottom, "edit " and "wipe" ) ... But CLI shows it as above "not available".
I'm transferring the volume to a couple Green6Tb's now.... I don't like NOT having the extra parity with the drive out.
I've been considering with the idea of bumping up the storage size, ... So this may be my chance to reflash that M1015.
I'd kind of like to figure this out, but may just rebuild the server, M1015/ more storage.
Thanks for your help.
